Old 03-07-2019, 04:37 PM   #15
my1stgen515
2019 2SS
my1stgen515's Avatar
Drives: 2019 2ss w LT1, Mosaic Black & NPP
Open road Chevy, union NJ.. stay clear!!
my1stgen515 is offline   Reply With Quote
Old 03-07-2019, 11:25 PM   #16
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
So did they install a factory NPP muffler? just with no actuators installed on it?
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 03-08-2019, 01:10 AM   #17
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
you could have bought a car with NPP. if they sold it to you as an option on a car that didn't have it and didnt tell you it cant be made to work they scammed you. call GM corporate.
Old 03-08-2019, 05:03 AM   #18
my1stgen515
2019 2SS
I will take my car to a different Chevy dealership I’ve dealt with in the past to advise me on the npp issue. I haven’t been under the car to know for sure. This dealer will also install my gm cold air intake.
Old 03-08-2019, 08:13 AM   #19
ecko04
Drives: Too many to list
NPP Exhaust questio??
You’re moving too fast. Before any additional parts are installed, whether by the new dealer or the old, you should address the NPP first. If they end up having to put you in a car that has NPP, you don’t want them to also have to swap the GMCAI. Furthermore, the code for the CAI calibration once used can only be used on the same VIN. Get the NPP addressed first since it’s actually an issue and once solved to your satisfaction then have the CAI installed.
Sent from my iPhone using Tapatalk Pro
ecko04 is offline   Reply With Quote
Old 03-08-2019, 08:21 AM   #20
6spdhyperblue
Drives: 2SS 1LE
If the car doesn’t have factory npp it will never have functioning npp. You need to figure out how to get the car u were supposed to get
Old 03-08-2019, 04:32 PM   #21
my1stgen515
2019 2SS
Yes. Very true. I didn’t mean to imply installing cai right away. I need to address npp first. I meant, I will deal with my alternate Chevy dealer moving forward.
Old 03-08-2019, 05:43 PM   #22
bullet3z
Drives: 2018 1SS 1LE
Have you contacted the Dealership that you purchased the car from about this issue? That is the first thing I would do. Everyone that has posted before me told you the same thing. If they do not resolve the issue then contact GM. There is nothing the other Dealership can do for you. You might want to talk to a Attorney to see if they can get involved if the Dealership does not resolve the issue to you satisfaction.
bullet3z is offline   Reply With Quote
Old 03-09-2019, 06:38 AM   #23
my1stgen515
2019 2SS
The dealer claims they told me there is no tune available for the radio. I took that to mean just that. I didn’t think that meant the system wouldn’t work and stays open all the time ( I don’t mind this at all). I thought it would fuction similar to my previous 5th gen were the fuse controls the flaps. The reason for this whole post is for other people not to make the same stupid mistake I made.
Old 03-09-2019, 07:09 AM   #24
6spdhyperblue
Drives: 2SS 1LE
There are some aftermarket catbacks that are designed to run without the valves like corsa. If u wanted to check them out
Old 03-09-2019, 07:24 AM   #25
guapo
Emerald Coast Camaros
guapo's Avatar
Drives: 2017 50th Camaro LT2/RS
I just installed an axle back from SOLO performance out of NY. give them a call they make them for v8 and v6. So im wondering if the originally dealer just installed quad tip exhaust and told you it was the GM NPP exhaust. For the NPP they would have to install the muffler that has the NPP with quad exhaust on it. I believe that would have been upwards of 1500 to install. That would have me believing the dealer was not on the up and up and knew it. The tech that performed the work should know the difference and contacted service manager and explained the issues. I will post up a picture of the factory NPP as I just took mine off. good luck
2017 LT2/RS, 50th addition. Airaid CAI, Solo Performance Axle back, sunroof, Smoked Led Markers
guapo is offline   Reply With Quote
Old 03-09-2019, 08:26 AM   #26
my1stgen515
2019 2SS
Thanks for all the feedback guys. I will defiantly take all your comment under advisement
Old 03-11-2019, 03:34 PM   #27
MackSteelPrivateEye
Yours is a 2ss....I thought NPP was standard on the 2SS?
Old 03-11-2019, 03:37 PM   #28
JCunningham
Drives: 2017 2SS M6
nope just hard to find a 2SS with out it.
