Old 03-05-2019, 12:16 PM   #15
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
18's, those will fit?
gotswap is offline   Reply With Quote
Old 03-05-2019, 12:20 PM   #16
UrbanKnight
Drives: Fastish
Yep!
We already did a test fit, then they decided to make a few changed to backspacing to accomodate my requests...
Going to be running 315 Fronts and 335/345 rear hoosiers. I have a couple pics of the test fit I'll post
The rim with tire is a 345/30/18 Hoosier A7. Bare rim is front clearance on brake caliper. We decided to suck the rim in about 1/2" front and rear for clearance. Going to be 18x11 front, 18x12 rear. We could of went 12.5 rear, but wanted to allow some room for suspension travel
UrbanKnight is offline   Reply With Quote
Old 03-05-2019, 12:26 PM   #17
luv2ride
luv2ride's Avatar
Drives: 2017 ZL1 Camaro
Originally Posted by Brettmess24 View Post
Excellent! What is the track aesthetics?
Your going to love those wheels make sure you post them up when you get them.
What’s your thought on the +6 offset? Trying to tuck them in a bit more?
Track aesthetics remove material in the dish area of the wheel. Saves some weight and looks good, The picture of the wheels on the Corvette, has this applied. If you look at a stock picture of the RZ05's there is more material where the lugs reside.
I didn't want to run spacers on the ZL1. The stock offset for the ZLE is +11ET and most run a 5mm spacer to provide ample clearance on the MRC suspension. I really didn't want to clearance the strut, so I opted for the builtin offset. This will actually poke the wheel a bit more, however I run -2.7 degrees camber, therefore poke is not as noticeable.
luv2ride is offline   Reply With Quote
Old 03-05-2019, 12:36 PM   #18
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
Originally Posted by UrbanKnight View Post
I have a set of 18's on order (should be here next week) for track use. I live/work right by them. They asked me to come over to do a shoot with a stock size set last week...
https://www.bcforged-na.com/project/...W8DMiIASgLO5Vc
Great group of guys!
Edit- I ordered RZ05's for my track wheels...
I'm planning to order 18" RZ05s for track use as well, but I'm concerned about fitment. Another forum member with a ZL1 1LE mentioned that his RZ05s had a very tight clearance with the DSSVs.
Did you get any detailed assurance that your 18" RZ05s will fully clear the DSSVs and Brembos without spacers?
Edit--sorry didn't see your test fit post on the second page, I'll follow up with BC. Thanks for posting details and pics! With 315 front and 345 rear Hoosiers you'll have ridiculous grip.
SFV1LE is offline   Reply With Quote
Old 03-05-2019, 12:42 PM   #19
UrbanKnight
Drives: Fastish
Oh they will fit, or they will keep remaking them until they do ! LOL
I work about 3 miles from the office in Florida. Dan and the team there have committed to making sure we have a viable track option!
Old 03-05-2019, 01:02 PM   #20
SFV1LE
I'm considering 18x11 on all four corners so i can 1) use a few sets of existing R comps in my garage and 2) be able to rotate front to back on track.
#2 requires me to use spacers, or I could get different F/R offset to avoid spacer and lose the full rotate capability.
Another option is a second set of rears only in 12". The track I frequent most often is Auto Club Speedway ROVAL in Fontana, and the high speed (~140-150 mph) banked oval turn 1-2 can burn through right side tires fast, so I always bring 2 sets.
Old 03-05-2019, 01:04 PM   #21
Brettmess24
Drives: 17 C7 GS WGG
Ah ok those are my wheels that I posted on my C7 that I’m trading for the ZL1LE
Brettmess24 is offline   Reply With Quote
Old 03-05-2019, 01:07 PM   #22
Brettmess24
Glad I posted here!!!! Thanks for the info and pics!
Old 03-05-2019, 03:11 PM   #23
Repman
Drives: 18 Black ZL1-1LE
Here's mine , I hope this helps
Repman is offline   Reply With Quote
Old 03-05-2019, 04:38 PM   #24
2010REDSS
2010REDSS's Avatar
Drives: 2018 ZL1 1LE
Here's mine.. ZL1 1LE specs in 18".
Strong, light, good looking, reasonably priced.
2018 ZL1 1LE "RAZECAR"
2016 2SS Convertible "NOTOPSS" (Sold)
2015 Z/28 #306 "ITZFAST"
2010 2SS Coupe "FASSTER" (Sold)
2002 SS/RS "02FASST" (Sold)
2007 Factory Five Racing GTM "REDBLUR" (Sold)
"There are two kinds of cars. Red....and everything else!"
2010REDSS is offline   Reply With Quote
Old 03-05-2019, 04:55 PM   #25
SFV1LE
2010REDSS, very nice! What track tires are you running on those 18s? Thanks
Old 03-05-2019, 05:40 PM   #26
2010REDSS
2010REDSS's Avatar
Thanks! 305/660/18 front and 325/660/18 rear Pirelli DH Compound Slicks (scrubs).
They work spectacularly.
Old 03-05-2019, 05:53 PM   #27
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Those the wheels that were on their ready to buy (SHOP) list on the website?
Looks like the front struts were in STREET camber during the shoot?
Looked at those multiple times, but, leaning towards 18" since I have multiple sets of 19". Car looks good on them!
RUQWIKR is offline   Reply With Quote
Old 03-05-2019, 06:23 PM   #28
UrbanKnight
Drives: Fastish
For the test fit with Hoosier and the 18”, bare rim in front. I was on street alignment. The photo shoot with the stock sizes, I’m at track alignment. -2.7 front,-2.1 rear
