Old 02-28-2019, 07:51 PM   #15
18ss376
Drives: Camaro
No one races dynos, but an e.t. slip is the real answer.
18ss376 is offline   Reply With Quote
Old 02-28-2019, 08:20 PM   #16
Whocares05050
Drives: 2018 Camaro SS 1LE
Without a stock baseline the final # is pretty pointless
Whocares05050 is offline   Reply With Quote
Old 02-28-2019, 09:57 PM   #17
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by JonD View Post
Good lord those are high & the shop claims it’s lower than others!?
Marketing at its finest people...
+1
Old 02-28-2019, 11:09 PM   #18
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
37*F with no correction factor and a m6? Yeah probably right.... but you are cheating yourself unless you race in 37* weather
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 03-01-2019, 12:13 AM   #19
Chef-j
Drives: 2018 Camaro 1SS
You are saying its 600 whp on Dynojet? Lol wake up my man. Your tuner should have an explain better for their customers.
2018 1SS 6MT: SOLD
Chef-j is offline   Reply With Quote
Old 03-01-2019, 09:37 AM   #20
PRAY
PRAY's Avatar
Drives: 2016 2SS
STD is still a correction factor but will read 10-12rw higher than SAE. But it isn't UNCORRECTED. I must say I am not a fan of operator input dyno's. But they seem to be very good tuning tools vs the normal DJ. Even if these numbers were UNCORRECTED in that weather they wouldn't be that high on a DJ. UNCORRECTED in that weather with your mods could get you to near or at 500rw but the correction factor should be .95-.96. The most I have ever made FBO on a DJ in 6th through an A8 was like 498rw SAE. The M6 will put down a bit more power than an A8. Like the others said, track mph calculated with weight and DA will tell the real story.
Old 03-04-2019, 07:11 PM   #21
parish8
Drives: 17 SS a8
I think you guys are under estimating the cold air. I used a calc and entered 37deg, 20% humidity and 31.006 in/hg(105kpa) and it kicked out a sae correction of .892
525 * .892 = 468hp
edit: I just looked up some weather around that date in that area. 30.3 in/hg and more like 50% humidity along with the 37deg are more realistic numbers. that gives a .919 sae correction.
525 * .919 = 482hp
Old 03-08-2019, 09:17 PM   #22
NickyRacerBoy
Drives: 1LE
I have MSD ported by pray ZR1 ported by prey custom tsp camshaft on a 112 lobe separation tsp ported heads E85 long tube headers and I made 5:35 on a Mustang
NickyRacerBoy is offline   Reply With Quote
Old 03-10-2019, 07:48 AM   #23
JonD
JonD's Avatar
Drives: 2018 SS 1LE
Here is that shop on IG defending the latest 535whp simple bolt on TL1
I just want to see the baselines on stock cars before mods
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune
https://instagram.com/corn_sauced?ut...d=o0ako89uurwl
JonD is offline   Reply With Quote
Old 03-10-2019, 05:53 PM   #24
Chef-j
You can just take it to different shop if you like to know. Just run same gear on dyno.
2018 1SS 6MT: SOLD
Old 03-10-2019, 06:05 PM   #25
JonD
JonD's Avatar
Drives: 2018 SS 1LE
I’m nowhere near this shop nor would I take it there.
I want these customers to see the difference; nobody has a baseline to compare as no LT1 with basic bolt on’s is making that much power that’s being promoted.
Gains vs. Dyno #’s
Old 03-12-2019, 09:56 AM   #26
CJack2005
TEXAS WFO
Drives: None
With a good drag pack the 1/4 mile rarely lies, its never generous and usually is the only true indicator on the big end of the track how much power you make.
There is the truth............ good post.
I can't get to terribly excited over dyno numbers, its a tool nothing more nothing less.
CJack2005 is offline   Reply With Quote
Old 03-12-2019, 09:58 AM   #27
Cerberos
Drives: 1976 camaro
Wit a stock throttle and a unported msd manifold i got 469whp on 80% humidity and 85F, thru an auto, the stock baseline was 385whp, i would expect around 480whp wit your mods
Cerberos is offline   Reply With Quote
Old 03-14-2019, 09:51 PM   #28
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Baseline would have been 480HP....
