02-16-2019, 04:54 PM | #15 |
Drives: 19 zl1 Join Date: Dec 2015
Ahhh yes I see. Very well done mlee.
Thanks man |
02-16-2019, 05:07 PM | #16 |
When you get to using line lock at the track it's actually a really quick process. I made that video in the A10 but all the same applies in the M6 I have now. |
02-16-2019, 06:25 PM | #17 |
Drives: '18 RH ZL1 1LE Join Date: Apr 2018
@mlee I didn't realize that was yours, I would have given proper credit if so. Thanks for that vid.
02-16-2019, 07:12 PM | #18 | |
It was getting hard to explain it on the forums so I pulled out the video camera to make it easier. Just needed to take the car out of Park... |
02-16-2019, 07:26 PM | #19 |
Drives: 2018 hyper blue ZL1 1LE Join Date: Nov 2018
02-16-2019, 07:56 PM | #20 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
I have a m6. The line work works. Did a burnout in my drive way.
02-16-2019, 08:47 PM | #21 |
Yeah, once you have the menu on line lock it comes right back up... Then at the track you're going to be in track mode anyway so that's already done too.
02-16-2019, 10:11 PM | #22 |
So the process would be pull up to the staging lanes already in a PTM mode, line lock menu, burnout, and then just press and hold the traction control button to get out of PTM and shut everything off?
02-18-2019, 02:50 PM | #23 | |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
After finding out about Sport Competitive Mode, which works good at the strip as well, that might be the best way to go if you plan to use line lock, but not launch control or any PTM. Doing this, after the burnout you would press TC, push the mode button once to switch to Sport, then double tap TC to enter Competitive mode. Would only take a couple of seconds instead of nearly 10.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
02-28-2019, 09:32 AM | #24 |
Drives: 2018 Red Hot ZL1 1LE Join Date: May 2017
What tires are you going to use so I can buy stock?
2018 RED HOT ZL1-1LE: Nav,PDR,Floor Mats
Built! |
03-01-2019, 04:58 AM | #25 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Probably start with MT ET streets.
I have to get the car first. I’ll let you know when it arrives. |
