#15 | |
![]() ![]() Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
I can change it to a longer duration. I thought with the sensor being much closer now in the collector and the fact that the sensor is just beginning to heat up after the 1 minute duration that it would be enough time assuming it probably still needs a good 30 secs or more to reach it's fully heated operating temp. I realize 1 minute doesn't sound like much time but when you are just sitting there the car has actually had time to idle down and then some and I figured I'm probably going above and beyond what anyone else has ever done with a delay timer for a WB sensor. But I can make it 2 mins if you think that would be better. The issue I have with a switch is I didn't want to have to always remember to turn it off every time I got out of the car, etc. The timer resets the count down every time you start the car.
#16 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#17 |
Sounds like a placement issue. Put the wideband sensor up by the factory narrow bands and I doubt you will ever have a issue.
#18 |
![]() Drives: 2018 Camaro ZL1 Join Date: Feb 2018
Great info. Thanks guys!
#19 |
2016 loaded 2SS
Drives: Maverick X3 Turbo R Join Date: Feb 2015
Yeah I’ve already gone through one sensor. I will go ahead and change my wiring to the aem obd controller to have a TON delay and call it a day
And I thought I was the only one over here with an issue. I feel like the placement is ok in the caperformance cat deletes For those of you who want to do it too, you can use a device Similar to this Mini Timer Time Delay Relay .1 Sec to 400 days. 3V 12V 18V 5A. Power on or Off Delay, Cycling and More https://www.amazon.com/dp/B00PD65UGA..._XwezCb53TS5M9
#20 | |
That's exactly the one I'm using on mine. I am using the 10amp version and opted to use it to energize a 12v Relay to power my WB Sensor. |
#21 | |
Just for future reference if it ever comes to that. . Does the NTK WB sensor come with a compatible connector that would work with the typical AEM UEGO type controllers or does this require it's own proprietary controller? Thanks!
#22 | |
2016 loaded 2SS
i'm pretty sure they are stuck to 8 pin LS4.9 sensors.
