Old 02-10-2019, 05:46 PM   #15
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Blue loctite, been on for months.
1100 - 5/26
0000 - Cancelled - 7/5
Contacted Becky - 7/1
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 02-10-2019, 08:58 PM   #16
Grumpy1
Grumpy1's Avatar
Same, right at one year now.......
Grumpy1 is offline   Reply With Quote
Old 02-10-2019, 09:33 PM   #17
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
Left mine on, with blue loc-tite
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 02-11-2019, 03:13 AM   #18
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
9500 miles mine are still on with blue loctite
Old 02-11-2019, 09:31 AM   #19
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
I lost 1 the same day i installed. But I'm sure it was my fault from not tightening properly. Blue loctite never crossed my mind, nor replacing the proved bolts which was kind uncomfortable to tighten with the little tool they provided. All other 3 have held on for a year already.
Florida High Performance: H/C Whipple LME 377 900WHP
G2K is offline   Reply With Quote
Old 02-11-2019, 10:15 AM   #20
Bodyslide
Bodyslide's Avatar
Drives: Traded in 2016 BLUE VELVET 2LT RS
I have had mine on from since I installed them in Early 2017(15000 miles now), no issues. I guess I will check and see it they are loose the next oil change.
Bodyslide is offline   Reply With Quote
Old 02-11-2019, 10:26 AM   #21
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
Mine is still on after a year. No blue loctite. Just made sure that i tighten them down like crazy. I'll probably go back through with blue loctite.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 02-12-2019, 02:23 AM   #22
Frankie18SS
Frankie18SS's Avatar
Drives: 18 Camaro 2SS, 07 Saturn Ion
I was thinking the same thing. I tightened the heck out of them but I probably should throw some loctite in there too just to be sure.
Ordered from Becky D __ 2018 2SS Silver Ice Redline 6MN, NPP, MRC, GM CAI
Frankie18SS is offline   Reply With Quote
Old 02-12-2019, 03:27 AM   #23
Hero_Camaro
Hero_Camaro's Avatar
Drives: 2016 2.0T RS
Here is my personal experience on this, Yes, it is true these things become loose overtime! I was about to lose one of those lift pads but the other screw kept it holding nicely so I was lucky and took sometime to invest on those pads to realize where I went wrong. others on the forum were not lucky as seen from the comments on the topic and I don't blame you. I installed the lift pads on the end of May 2018 for those wondering how much it held up.
I have a few tips to share based on my experience:
1- Always keep the allan key in your glove box it is vital that you do it anything can happen keep it for emergency sake!
2- When you will install those pads they are actually installed incorrectly? Now you're gonna ask why or tell me that I'm crazy? The lift pads need to cover the entire pinch weld even the top part of it with no gaps or spaces (To simplify the top part of the lift pad which is the flat surface needs to be perfectly aligned towards the roof of the pinch weld which is on top of the pinch weld leaving no airspace on top) so how to do that?
You will need to regularly install those lift pads at first per the product instructions. Tighten everything hard as you can so they don't fall off while driving, when the car is being lifted by service on the lift the bolts will somewhat get a bit loose this is normal again due to pressure, the pads will automatically adjust due to the force being implied on the lift pads by the car lift so the bolts are still holding on nicely.
After your car is being serviced, retighten all the bolts properly you will notice that those gaps are gone. Explanation:The Pressure by the lift when the car is lifted allows that adjustment on all 4 sides since the top of the lift pad will stick to the roof leaving no gaps
3- Regularly check the lift points after each service by re-tightening the 8 bolts, there is no point of having a blue loctite on those they are not meant to have those, pressure needs to be distributed evenly at first by lift then retighten wherever necessary. I wouldn't recommend anyone to use blue loctite the idea isn't locking at first its adjustment then locking.
Hero_Camaro is offline   Reply With Quote
Old 02-12-2019, 07:04 AM   #24
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
let mine on as well they survived a trip to Camaro Fest
#TeamBeckyD
**FIFTY HBM 2SS VERT**
