#15 | |
![]() Drives: 1994 z-28, 2017 2ss 6spd Join Date: Mar 2018
Were you in 5th gear for your top speed of 182-813?
That's the way my 1994 is 5th gear for top speed and 6th is the overdrive. Quote:
#16 |
I have the service manual for 2016-17. 13,028 pages and I get only one hit when I search for "speed limited." Is it possible there was a thermal issue which triggered the warning? You did not mention any DTC, and I figure you would say so if that were the case. DIAGNOSTIC INFORMATION AND PROCEDURES > DTC C0574: PRINTED CIRCUIT BOARD TEMPERATURE SENSOR > ACTION TAKEN WHEN THE DTC SETS The electronic suspension dampening level is decreased or disabled. The Service Suspension System and Vehicle Speed Limited messages are displayed. |
#17 | |
![]() Drives: 2018 1LE Join Date: Jan 2019
#18 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS A8 Hyper Blue/White Stripes Join Date: Jun 2010
https://www.chevrolet.com/content/da...ro-catalog.pdf
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD |
#19 |
excellent thanks!
#20 |
![]() Drives: 2017 1ss 1le Red Hot Join Date: Jan 2017
Anyone know why the 1le is limited lower than standard?
#21 |
![]() Drives: Chevy Blazer Join Date: Sep 2009
#22 |
Good points.. I'm not sure how much the tire width makes but having more road resistance and wind drag from the tires I'm sure plays into the top speed. I'm sure someone will chime in with more info then me on that one.
#23 |
#24 | |||||
Boosted Moderator
Drives: Bone Stock LS3 Join Date: Sep 2009
I run lots of downforce but I'm not trying to turn.... I'm trying to not go flying.... The ground force slows me some but I just push harder on the loud pedal.... and.... "If you can turn, you are not going fast enough...."
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
#25 |
![]() ![]() Drives: 2021 BMW M2 Competition Join Date: Oct 2008
Is it possible the car was ordered with optional tires? I thought 1LE always came with Eagle F1 Supercar 3, and not sure if it's possible to order anything else, like run-flats or all-seasons. But with my old BMW at least, if you ordered the car with run-flats or all-seasons, the speed was electronically limited to 135 I believe, and changing the tires later would not change it. Can you check the build sheet or use a VIN decoder to see the original options?
2021 BMW M2 Competition 6MT
2011 Candy Lime Green Kawasaki Z1000 (1/4 mile - 10.38 @ 129.61 mph - stock) ---------- Previous: 2018 Summit White 2SS 1LE; 2015 MINI Cooper F56 6MT; 2015 BMW M235i 6MT; 2003 MINI 5MT; 2005 Mustang GT 5MT |
#26 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
I think someone set this in the initial menu. You need to have the "code" thats been programmed. I think you can reprogram. Car has to be parked with parking brake ENGAGED.
2012 Yukon XL Denali w/ 6.2 AWD |
#27 |
Can offer more detail on this or point me in the right direction in the manual. Also to another above poster, it came from the factory with the standard 1le tires.
#28 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
Not sure the limiter is actually set lower in the 1LE. However the wider tires in my opinion will slow it down a little (more aerodynamic drag) compared to the normal SS with the skinnier tires. Don't know how the 1LE's front splitter/rear duckbill spoiler compare to the no splitter/rear wing setup of a base SS as far as drag. I have only seen 1LE cars in passing, do they use the front tire deflectors under the bumper like a base SS does? The parts that I'm talking about are the ones that get removed when you install the SS brake deflector kit for road course use.
