#15 |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
The straight boots are bendable on the MSD wire we bend them 45 degrees and they clear the header tubes perfectly and never have a burned wire again.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#16 |
![]() ![]() ![]() Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
I received the covers today and I think the MSD wires are on the way. Thanks Ted.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
#17 |
Awesome Sauce.
#18 |
![]() ![]() ![]() ![]() Drives: Black 2017 Camaro SS 1LE Join Date: Dec 2016
These are the ones I went with when I had the same problem happen twice. Loved that you could bend them to fit your application. Still threw the heat socks for the extra protection. Also swapped the oil out after dumping a bunch of fuel.
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
#19 |
![]() Drives: '18 SS 1LE M6 Join Date: Feb 2018
I've heard of several others having this problem.
Went with the bendable MSDs & ceramic coated the headers all at once. 3k miles later and the wires look brand new
'18 1SS 1LE M6 NGM|| 11.5:1 Diamond Pistons || Callie's H-beams || Vengeance III Cam Kit || Built Heads || TSP LTs 1 7/8"(C-Coated) || MSD IM || DSX E85 || Rotofab || BMR Springs || 576/472 @7000rpm
#20 |
|Engineer|
Drives: 2016 Camaro SS Join Date: Aug 2016
I still haven't solve my misfire issue. Wonder if its something similar.
2016 Camaro SS A8 | Magnuson Heartbeat | Might Mouse Wild Catch Can | DSX Flex Fuel | Eibach Pro Kit | Flowmaster Outlaw Black Series | MRR 017 Wheels
#21 |
What kind of misfire are you having? Mine was a dead miss...if you are having the misfire, it should be visible in the logs.
#22 |
|Engineer|
If I am in a low rpm and go heavy with the throttle, it will feel sluggish, hesitate, makes a odd sound and the misfire count will go up on #7. I haven't gone WOT since the first time it happened, but on smooth yet heavy rolls, it will do it from time to time. If I go nice and easy, no misfires.
#23 | |
![]() ![]() Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
#24 | |
#25 | |
