#15 |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2017
The Alky Control kit does not come with a tank..it uses the washer fluid tank. I think the kit from Snow Performance has a trunk mounted kit. My installer recommended the Alky control kit as they use steel braided lines and is overall a higher quality system.
#16 | |
![]() Drives: DZ Join Date: Aug 2018
If I had any complaints - it would be the instructions. They give you a set of pretty much text only instructions on about 10 pages of paper, most of which are 5th gen instructions adapted to the 6th gen. IE- they want you to mount two LED lights in the dash, with pictures of the 5th gen dash. Where they have the LEDs, there is no way they would work on the 6th. The install is not for the faint of heart. Remove nose, passenger fender, modify tank, tap vacuum source, mount Alky MAP sensor, several electrical runs (MAP signal, 12V hot, 12V switched, tank sensor switch, remote unity, controller, and two LEDs), run pressure lines, mount new windshield tank, extend windshield lines, extend washer wiring (I am actually putting a 2qt washer tank in the trunk) |
#17 |
![]() Drives: 2017 silver camaro ss Join Date: Nov 2017
With the lt4 blower did you go with map or maf set up
#18 |
Heater thanks for the reply.
