Old 12-31-2018, 10:40 PM   #15
Cobaltct
Drives: 2018 camaro ZL1 in Nightfall Grey
Originally Posted by ZL14ME View Post
+1
1200 miles on mine and when they squeak it’s always just break dust buildup. Usually on the rear brakes. A good cleaner has fixed my issues. I prefer Chemical Guys. I’ll replace the brakes sooner or later.
I just washed the car over the weekend I'm a detailer, the wheels were cleaned thoroughly...
Cobaltct is offline   Reply With Quote
Old 12-31-2018, 10:43 PM   #16
Cobaltct
Originally Posted by unavailablezl1 View Post
I take long breaks at lunchtime, but they don't squeak
Hey man auto correct sucks sometimes I should have read it before I posted lol
Old 12-31-2018, 10:48 PM   #17
Scraps0f
Drives: 2018 NGM ZL1
Could you have maybe over washed the rotors, like back to new?
Scraps0f is offline   Reply With Quote
Old 01-01-2019, 01:38 AM   #18
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
I see so many people saying "breaks" instead of "Brakes" on here and other sites. NP. Fun is where you find it, right?
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 01-01-2019, 01:41 AM   #19
unavailablezl1
My zl1 has 1700 miles on it and the clock, my brakes are really squeaky like nails on a chalkboard squeaky. Anyone else have this issue? Any fixes for this thanks again
Mine squeaked a lot when the car was new. Most cars do. The pads are raw and rough and wear down fast until they are in a "burnished state" and then smooth out and are quiet.
Current ride
Past Rides
Old 01-02-2019, 07:36 AM   #20
Cobaltct
Ok thanks man I guess I will just have to wait lol
Old 01-02-2019, 09:52 AM   #21
jbp8653
jbp8653's Avatar
Drives: 2017 ZL1,2013 ZR1, 1952 C3100 Resto
Had the same issues. Replaced pads with ceramic one's. Issues solved with a very,very slight reduction in stopping power. As a bonus, no dust. If you track the car you will need to put the factory pads back on.
2017 ZL1,Mosaic Black, auto,nav/pdr, Roto Fab,Mamo
2013 ZR1 60th Anniv.
1952 C3100 resto-rod. LS6, 4L60e, 228R cam
jbp8653 is offline   Reply With Quote
Old 01-02-2019, 11:20 AM   #22
Firehead640
DEVLMAN
Drives: White 2018 ZL1
Just do some hard braking and it seems to go away. Mine were doing this recently (2 days ago?) and I just did 3 or 4 hard/late brakes to a make a turn and everything was okay.
The 6-piston Brembos just have this issue, they are noisy brakes. Even the cars at Bondurant(Challengers) had loud brakes.
Firehead640 is offline   Reply With Quote
Old 01-02-2019, 11:25 AM   #23
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
This.
Powerstop Z26, about $125 for both front and rear on Amazon. Cheap, no noise, no dust. Reduction in performance is negligible on the street, but they are not track pads.
Brake pads are very easy to change out w Brembo calipers.
Old 01-02-2019, 11:55 AM   #24
HDRDTD
OK, here's another idea, but it normally applies to brake pads that have been just installed.
When installing brake pads, they come with a small tube of special high temp brake grease that you apply to the BACK of each brake pad where it meets the brake piston to prevent squealing.
If that grease is missing, it could cause your brakes to squeal.
Old 01-02-2019, 01:39 PM   #25
Cobaltct
Originally Posted by DaveC113 View Post
This.
Wont I need new rotors as well?
Old 01-02-2019, 01:45 PM   #26
DaveC113
DaveC113's Avatar
No. Ideally, you'd resurface them by machining or sanding but IRL it's rarely necessary. I had no issues just throwing on the Powerstop pads, and for track use, maybe a light sand + burnishing when putting the stock pads back in should be fine too.
Burnishing is in the owners manual I think, it's just a series of hard stops.
Old 01-02-2019, 02:05 PM   #27
collinms
Drives: 2017 ZL1 A10 Summit White
In my opinion if you put those brake pads on this car you have no business buying the car in the first place and should have just gotten a SS. Don't listen to people that say braking performance is not changed much, it's a lie. If you bought the ZL1 to go to parking lot shows then yes, it will be just fine. If you drive your car aggressively and do mountain runs or other performance driving you will not be happy.
collinms is offline   Reply With Quote
Old 01-02-2019, 02:25 PM   #28
DaveC113
DaveC113's Avatar
If you outdrive Z26 pads on the street you're driving far, far, far above the speed limits.
I'm not making any judgements, but some of us save that for the track and drive well within the performance envelope of Z26 pads on the street.
In my opinion, your opinion is on the fringe. Not how most drive... thank god. I hope you never hurt anyone.
