#15 | |
![]() ![]() ![]() ![]() Drives: 67 goat, 69 goat ram air III Join Date: Mar 2009
https://www.transportenvironment.org...noise-limits-0 |
#16 |
![]() Drives: 2SS, Hyper Blue, Sunroof, NPP, MRC Join Date: Jul 2016
Had mine replaced at the dealer last month, it's covered.
#17 | |
![]() Drives: 16 2SS Blue Velvet (SOLD) Join Date: Apr 2017
GPG |
#18 | |
Moderator.ca
CAFE has nothing to do with sound. CAFE is Corporate Average Fuel Economy. Noise regulations exist, but not as part of CAFE. Urea is not made from urine. Its found in urine. But thats not the most economical source. Its made, more or less, from combining ammonia with carbon dioxide at high pressure. Also about urea, manufacturers are not specifically required to use it in diesels. Its just the most effective way to meet emissions standards at the moment. But if a solid-state catalytic converter could be made at an affordable price that does just as good a job (or better), it would replace the DEF + SCR combination currently used. And American diesel emission standards are what they are so that they're in line with cars, instead of being held to a lesser standard like in the past. The standards in Germany, while being higher on paper, were actually much easier to meet. Its like saying students in one school are better at math because they all get A's or A+'s on their test, while kids in a different school average around a C. But the first test is merely adding single digit numbers together while the other is multi-variable algebra. And as for DEF 'doing nothing', I don't know about you but I'm not a fan of breathing in nitrogen dioxide. It does a whole range of things to your lungs, none of them are good.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
#19 |
![]() Drives: 2018 Camaro 2SS Redline Convertible Join Date: May 2016
Here is the solution I came up with to handle those flimsy peeling vinyl engine cover letters. Ordered painted covers from RPI and got a great job that was well worth the dough.
2019 Buick TourX
2017 Colorado Redline 1966 Ford Mustang Pro Touring |
#20 | |
![]() Drives: 2016 Camaro 2SS A8 Join Date: Nov 2018
Took the plunge myself. They came out nice.
#21 |
![]() Drives: '17 2SS Vert H50, A8, F55, NPP Join Date: Jan 2018
#22 |
#23 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
I did the same ![]() Ryan B.
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
#24 |
#25 |
![]() ![]() Drives: 2016 2SS, Red Hot, NPP, Nav, M6 Join Date: Jul 2016
Mine are also starting to peel the paint off for no apparent reason. No harsh chemicals ever or anything like that.
Those that got covered under warranty, are the replacements holding up, or is the vinyl from e-bay the way to go for longevity? Any issues with the vinyl adhesion? |
#26 |
![]() Drives: 2016 Summit White Camaro SS Join Date: Jul 2018
Same thing happened to mine - after I convinced the dealership that they actually came painted from the factory, they ordered new ones and replaced them, no charge
#27 |
![]() Drives: 2016 2SS Join Date: Jan 2016
Went to my local dealer (Medved) with my peeling letters and the guy said 'thats a cosmetic problem and is only covered on the 12mo/12k warranty'. So I called another dealer a little further away and said 'I will order you a new pair today under warranty, when do you want to come have them installed?'
#28 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 SS 1LE Join Date: Dec 2015
The gray/black cover in the center that goes over the intake manifold has some insulation under it. |
