#15 |
![]() Drives: 2018 1SS 1LE Join Date: Jul 2012
Their stage 2 and 3 are in my list of considerations. When are you doin the install?
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD |
#16 |
![]() Drives: 2018 Camaro 1LE Join Date: Dec 2018
Y’all arent making me feel very good about my choice of lifters...
#17 | |
Now when you start moving up into the stage 3 stuff like VVT-3, Polluter, SSi-3/4...etc, using high seat pressure dual springs, and revving the engine to 7200rpm, then it would be wise to use something like a Johnson 2110. I would say based on looking at different cam and spring packages. LS7 is probably ok up to Stage 2 or cams where the engine rpm isn't going to exceed 6800rpm and require a heavy spring to keep things in control. jmo ymmv.
#18 |
Well that’s what I’m using. GPIs SS4 cam and the Brian Tooley springs. I typically shift 6700-7000rpm. Rev limiter at 7200. I really wish I would have upgraded. I just knew at the time to upgrade the trunion to get rid of those needle bearings. Would I have known the ls7
Weren’t that great I would have optioned the Johnson lifters as well. I asked GPI what they would recommend upgrading and they said ls7 lifters are fine |
#19 | |
![]() Drives: 21 SS Join Date: Oct 2017
I almost went vvt 3 but after placed my order went to Vvt2.
FBO, E85
11.1@123 |
#20 | |
42pack
His tsp vvt2 cam was early days before 0 degree lock, you think that will offset losses under 4000? Plus I will have ported stock manifold and think with my tuner he can tune with no loss anywhere.
FBO, E85
11.1@123 |
#21 |
Why did you settle on VVT2 instead of 3?
#22 |
Didnt want to to much chop, or interior rocking..and wasnt impressed on any 1/4 miles people have done with vvt3
..just based on videos ive seen.
FBO, E85
11.1@123 |
