#15 | |
![]() ![]() ![]() ![]() Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
If you're going to enlarge for a 10", you'll need to go passenger side opening and make it offset of the existing hole. The deck is part of the rear cross brace structure, so the vertical plane is in the way if you stay centered. This will mean the edge of your sub will be firing almost directly at the bottom of the rear window seal. You can't use the driver side without having to extend cabling and relocating the trunk light/harness. If you go with the 8" subs, you can keep them centered with the existing openings and don't need to expand them because the opening is sufficient to pass the volume of the surface area. No relocation of light needed either. May just need to reroute and secure the harness down the middle on the topside of the deck. Enjoy! |
#16 |
Something else I was thinking about for both of you -- if you're going to use the rear side speakers, what are your plans to secure the speakers? If I recall, those speakers mount to the interior trim panel and aren't secured to the body structure behind them, essentially they are bottom mount. Adding a harder hitting or heavier speaker there could have unforeseen wear on the trim panels.
I honestly would just stick with 3-way active fronts, plus or minus the center channel depending on if you want driver only or both front seats imaged, and subs in the rear deck doing that IB sexiness. |
#17 | |
![]() ![]() Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK ![]() Last edited by drfeelgood; 01-11-2019 at 04:00 PM. |
#18 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 SS 1LE Join Date: Dec 2015
Ok you sold me on the smaller woofer. The work for a 10" sounds like a PITA. Just now reading about the I6SW, now that could drop in the stock holes without any cutting.. although an enclosure would be required.
I'm not doing anything for rear side panel speakers, in fact I'm debating on gutting the stock ones. One of them has a bad rattle. Sorry to hijack the thread OP. |
#19 |
drfeelgood, I was asking you how you planned to address securing the rear sides.
WhyUMad1LE, the 6.5 sub may be too deep to top mount with the rake of the back window. Have a contingency plan to bottom mount and then consider whether you want to move to 7-8" woofers instead for most surface area without modifications. |
#20 | |
For me, I'm subject to the constraints of the convertible*, hence me doing this the way I am doing it. I am interested to see how it sounds.
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK ![]() Last edited by drfeelgood; 01-14-2019 at 12:40 PM. |
#21 | |
![]() Drives: 2018 Camaro ZL1 Join Date: Feb 2011
#22 |
A 3.5" fits in the center channel location, but not in the dash corners.
#23 |
#24 |
exactly... those corners are very tight, both diameter and depth are a challenge there
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK ![]() |
#25 |
![]() Drives: 2018 silver Camaro SS Join Date: Jan 2019
my last car had both tweeter and mid in the same dash location firing off the glass. (Toyota 86) speakers were focal flax. I'm now putting the same speakers in my Camaro but am wondering if I should fire off the glass or place tweeters in the pillars an mid on the dash. as far as time alignment what will create the most accurate sound? I'm using the same amp i ad before (VXI 600/6) all I've installed so far is a 600.1 and fix 82(for optical output) with a 10tw3 wedge box and am leaning toward the w6 stealth box.
#26 |
I am going mids in the dash, and possibly tweeter in the a pillars as well. I will also go with the w6 stealth.
#27 | |
#28 | |
