#15 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
As far as airflow into the engine compartment, mine did have the same duct/shroud removals or modifications as yours, since it was the exact same kit (ECS/Paxton) as you have. I ran that setup to just over 125mph and did not see any pressure change going on like you are reporting. My sensor was mounted between the intake manifold and driver's side coil cover, tied to the wiring bundle that is there. |
#16 |
![]() ![]() Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
awesome info in here, I also found an issue with my car, the MAF extension harness provided by procharger had 7 out of 8 pins in it. I was able to disect the 8th pin out and plug it in and it fixed the IAT issue i was having as well as my fan staying on high. I get my IAT / Baro breakout harness today and hopefully DSX sends installation instructions as I would like to see where things are best mounted before I drill into my MSD intake.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
#17 | |
![]() Drives: 2017 50th Camaro SS Join Date: Jul 2016
Got mine from DSX a few days ago. No install instructions. I did find out the tap is M14X1.50 and you can use a 1/2" drill bit to make the hole. Tested mine on a thick piece of plastic. We will be installing end of the month when we install full LT4 fuel, DSX E85, auxiliary low side pump, meth and converter. It will be a LONG weekend, LOL!!
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
#18 | |
#19 | |
Post up how the install goes if you get a chance. I ordered the Alky Control MAP based kit. I have to say I was impressed as hell how well the kit was put together. Everything included done to wire ties and heat shrink tape.
#20 |
i will, I might just record me doing it and post it up for reference. i was going to go alky but i didn't like its mounting on the side of the fender so i went with RPM as it seemed to be a cleaner install. If i could go back i'd go alky all the way. There was some key things missing with RPM's kit. the DSX aux pump came with crazy good instructions btw, super simple install.
#21 | |
Yeah a video of install would be great.
#22 | |
![]() Drives: 2017 1SS A8 Nightfall Gray Join Date: Feb 2017
#23 | |
For the moment we're going to stay with 4" pulley although my tuner says 3.7 should be fine. I want to make sure we are good on fueling first. I am still on stock cam. Also am concerned with dialing up the boost too much with stock pistons and cam.
#24 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
If you have sufficient fuel flow and your tuner doesnt go crazy with the timing you should be fine. It is large amounts of timing which cause increased cylinder pressure which causes extra heat and the lack of fuel that cause the cylinder temps to climb, once things get hot the gaps go away and that is when the rings and or pistons start to fail.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
#25 | |
So do you feel pretty safe at the 650 HP level with your mods? I didn't see forged internals so I'm assuming you're still SBE?
#26 |
BAMF SS
You will have enough fuel to go with a 3.7 pulley. Ask me how I know.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
#27 |
![]() ![]() Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
I was running the 3.7 pulley w/No issues on LT4 Fuel, JMS Bap and E55. Stock Cam. Boost w/headers no cats was right around 9 to 9.5psi at 6500rpm.
#28 | |
Yes, car has been at 650 for well over a year. If I could get to E55'ish it would make more power but for some reason the fuel system doesnt handle much over E45 without dropping below 2500psi on the high side.
