#15 | |
![]() Drives: Yellow 2018 SS Join Date: Jun 2011
Dropped it off last night, should hear something today by noonish. Will update. |
#16 | |
#17 |
![]() Drives: 2018 SS 1LE Join Date: Apr 2016
Do you think a screen mesh in-front the aux radiators worth the effort or just leave as is?
#18 |
Just got word from the dealership. Rock busted my radiator. $1600 to replace.
I'm thinking that mesh might be worth it. Ugh, this really sucks. |
#19 |
Holly shikes.. $1600 installed at delearship? I would look at Rock Auto for aftermarket. Hopefully the part number is listed on the qoute.
If you don't mind if you have it specify part number to document for the forum |
#20 |
Looks like Mishimoto Automotive has the aux radiators for $450.00
Plus a DYI video. Hopefully this can help in the pain https://www.mishimoto.com/chevy-cama...MMRAD-CAM8-16S https://youtu.be/iyWUy9WJjy8 |
#21 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 1SS 1LE Join Date: Sep 2017
I wonder if this becomes a common issue, rocks puncturing one of the radiators, window screen material might be used to prevent rock contact.
'18 1SS 1LE Black, PDR
#22 |
![]() Drives: 2018 1SS 1LE HBM Join Date: Jul 2014
Ouch, $1600 seems a bit steep. I saw the invoice for mine and although they are submitting it under warranty they listed the labor at roughly $240, the auxillary radiator at $250, and the super rip off of coolant for $40. Was thinking the same about the wire mesh screen as a buffer and going to look in to fabricating something when I have some time. Also I found the auxiliary radiators for $121 at GM parts store.
#23 |
![]() Drives: DZ Join Date: Aug 2018
GM PN 2337751R is $117 on GmPartsOnline.net
#25 |
I’ve had a slight drop in the both reservoirs, should I be concerned?
#26 |
![]() ![]() Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
#27 |
It dropped about half in the main reservoir and the reserve was almost empty. So I filled up both, the reserve to the line limit, now the reserve reservoir is half under the limit line in about 3 months and the top reservoir remained full?
#28 |
Kevin
Drives: 2018 Callaway Camaro ZL1 1LE Join Date: Apr 2018
You probably had air in the system when the top tank was half full. Over time the air probably worked its way out and that's why you now have these levels. I would fill the bottom tank to the fill line, which is about half way, and monitor from here on out.
