Old 12-13-2018, 09:10 AM   #15
oldman
Drives: SS 6 speed of course
Originally Posted by Umbriel View Post
Yes that would get you there but cheapest would be nitrous.
note not for a road race....
Old 12-13-2018, 09:30 AM   #16
oldman
Originally Posted by 18ss376 View Post
Here is a guy with ZERO internal mods, just bolt-on's. This is well over 600h.p. I bet.
Originally Posted by Snowblind View Post
Update;
Tires used on the pass: MT R's 305/17
Performance Mods (if any): CAI, LT, UDP, WR, E85, Skinnies, PIM, PTB, gears, cat&muffler delete.
Category submitted for: Please List the Category or Category # 3. Bolt on no internal mods
R/T..........
60'............. 1.42
330'........... 4.34
660'........... 6.735
660’ mph... 102.31
1000'.......... 8.815
1320'.......... 10.581
1320’ mph… 127.88
Name of the track: Atco
Date of pass: 10/19/2018
Weather conditions: Include Density Altitude if known. (Optional not required)DA 50
Attachment 961327
I was thinking that 600 engine was a little bit of an over estimate but using this: https://robrobinette.com/et.htm?weig...x=0&submit.y=0
Would look to be true, it takes HP, applied power over time to make trap speed... there is no fudging. Sure the car can be a little lighter with driver, I put in 3950 lbs race weight. OK then.
My ride, before blower, FBO including ported MSD, 103mm TB... vs Hellcat, it was all LT1 till I shut off at the top of 3rd.. So my car is about 3650 as it is a 1ss manual with no options, the Hellcat is what 4500 lbs (I had a supercharged Challenger since 09),... That is almost 900 lbs extra. OMG (Hellcat is an all season tire)
Old 12-13-2018, 09:32 AM   #17
oldman
Originally Posted by danhr View Post
My car made 500+ rwhp STD on a dynojet, and it baselined at 380 rwhp (a8). With a baseline of 380 rwhp and the 455 rating, that would be 16.4835% drivetrain loss.
500 / 0.83516 = 599 crank hp.
To answer the original question.... just throw a nitrous kit on a stock car, you will be well over 500 rwhp and cheaper than anything else.
STD is unicorn HP, better to talk about actual HP or as measured CF = 1.0 would also be acceptable.
Old 12-13-2018, 09:36 AM   #18
oldman
so to sum it up if you need the extra for sure no fudge 500 wheel SAE on a dynojet. You need a small cam and the cheapest conical springs probably OEM LS7, or GM performance or sum'ting cheap. Cam Motion has a set too. So without labor, $600 more. Actually not too bad on change to a AFM compatible cam, as the heads don't have to come off.
Old 12-13-2018, 09:45 AM   #19
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I believe you need a large cam for 600whp. Small cam would be in the 550-570whp range. Brett has all the data on his FB page. His Stage 4 cam and stage 2 heads put down 580 on a A8 in 5th gear, which would be roughly 605whp if dyno'd in 6th 1:1.
Old 12-13-2018, 10:21 AM   #20
oldman
http://www.superchevy.com/how-to/eng...-lt1-cam-swap/
37 HP from a AFM cam, 50 sumthing with air filter. Actually, peak HP is around 6000 RPM... so it not very peaky, good for road race, really I would tighten the LSA to 112 to bring up the torque.
Oh and if the topic was not cheap on 500 WHP, but an optimal cam for a road race, I would pick something not too peaky and with a strong mid-range, here is a 113 grind the looks interesting. this cam would be faster in a road race or auto X, no matter the peak WHP. It will hold the rev longer, and have a HUGE midrange punch.
http://www.cammotion.com/gen5-lt-cam...238-113-5-3-5/
Oh, right, I meant 500 WHP
600 WHP with stock short block, dunno, FBO ported MSD 103mm TB, heads, big cam... 6600+ peak 7200 rev... I'd at least change rod bolts. Just don't know on this engine, as my last chevy was a LS1 and those bolts were trash. 2" headers for sure, off road or uncapped... still iffy but close. 416 no issue.
Old 12-13-2018, 11:04 AM   #21
KingLT1
KingLT1's Avatar
The bottom end is for sure more stout then the LS stuff. It should handle 7500 rpm in stock form. 6 bolt mains with nodular main caps, internal oil squirters, optimized crank case for improved windage control, bi-metal eccentric rod bearings that were tested at WOT for a duration of time with zero break-in, and a much improved thrust bearing which plagued LS1's. This engine is the "bees knees". The only thing limiting it's true rpm potential is the factory AFM valve train and the intake manifold. Put a high ram on it with some Johnson SLR lifters and a healthy cam... these engines will wind damn near like a Coyote 5.0.
Old 12-13-2018, 11:06 AM   #22
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
no such thing as "cheap HP".
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 12-13-2018, 11:08 AM   #23
62nalide
62nalide's Avatar
Drives: 2013 SS
Update;
R/T..........
660’ mph... 102.31
1320’ mph… 127.88
Attachment 961327
A car making 480whp is running just that and some faster and NO WHERE near 600whp.
62nalide is offline   Reply With Quote
Old 12-13-2018, 11:09 AM   #24
62nalide
62nalide's Avatar
Drives: 2013 SS
Cheap and HP don't mix well.
Old 12-13-2018, 11:09 AM   #25
KingLT1
KingLT1's Avatar
I scaled mine at the track with me in it & 1/4 tank of gas weighed 3900lbs.
I was referring to weight without the driver. subtract that minus 200-250lbs of weight reduction that is pretty common across all of the current mid 10 second bolt-on cars and you are right in the ball park of what I previously stated...and none of them are close to 600whp. All 480-500whp tops.
Old 12-13-2018, 11:10 AM   #26
Umbriel
Drives: 2016 Camaro SS
note for a road race....
Lol, yeah he wouldn't want nitrous if he is doing road racing.
Umbriel is offline   Reply With Quote
Old 12-13-2018, 11:16 AM   #27
Umbriel
Why would you refer to weight without driver? does the car go down the track by itself, I always factor the driver weight into my formulas.
Probably because they vary from 80 pounds to 500 pounds?
Old 12-13-2018, 11:46 AM   #28
lawguy85
Drives: 2018 Camaro 1SS Silver Ice Metallic
/endthread
Everything listed is several thousands of dollars. “Least expensive” is the question, cheap is impossible
lawguy85 is offline   Reply With Quote
