Old 01-21-2019, 09:14 AM   #15
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Originally Posted by grampa_ss View Post
check your math again. It's not even close to 2.6 inches taller. Circumference and diameter are 2 different measurements.
275x35x20 is 27.6" stock diameter
305x35x20 is 28.4"
it's like 3/4" taller than the front and does not cause any stabilitrack issues.
Ahh ok gotcha. THanks for catching that. I was focused on the circum. Good info!.
Thanks!
Dysan911 is offline   Reply With Quote
Old 03-14-2019, 04:10 PM   #16
FrostySS
FrostySS's Avatar
Drives: 2018 Redline Edition 2SS
555r...drive nice, work in the rain, and hook. They last about 10k miles if you are not beating on them every light(I have even seen reports of 15k miles but I think that is a stretch). Being you are in Florida I wouldn't even think twice about running them. on 47 degree roads I was out pulling 3.4-3.5 0-60's like it was a bracket car with bolt-ons and e85. With run flats it wouldn't hook under 40 in those temps.
Are you running the actual DR's or the G2's? I wonder what the main difference is.
2018 Redline Edition 2SS- A8, NPP, MRC, Recaro seats, ECS Novi 1500 tuned by EFX, cat deletes, Mighty Mouse Wild CC, GM STB, smoked ZL1 3rd brake light, Xpel XR Black 35% tint all around, Street Scene front splitter, C7 Carbon ZL1 side skirts Drake Muscle Car wicker bill, Adams Polishes Ceramic Coating
2010 Infiniti G37x Sedan for the DD.
FrostySS is offline   Reply With Quote
Old 03-15-2019, 07:45 AM   #17
grampa_ss
grampa_ss's Avatar
The main difference is the 555R will hook way better than the the G2. The other main difference is the 555R will wear much quicker than the G2.
I run all seasons for the winter for errands and stuff. But in the summer I run the 555R 305/35/20.
Old 03-15-2019, 12:52 PM   #18
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | 18 F150
if PS4S is too much for you at 520whp I'm wondering what you're doing TBH. I can only assume not letting them warm up.
Get a set of ZL1 1LE wheels and go with Supercar 3R or NT01 then if a PS4S isn't enough
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!)
'18 F150 Platinum Powerstroke diesel
'22 Kia EV6 First Edition
'18 RS3 (1 of 2) Cumulus Blue
'24 911 T (ordered)
Formers...
'19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
Old 03-15-2019, 12:58 PM   #19
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
PS4S and if you get wheel spin, treat throttle like analog input, not on/off.
ing for grip.
http://www.motorsportsne.com/
Old 03-15-2019, 03:55 PM   #20
Shawnqa800720
Shawnqa800720's Avatar
Drives: 2018 1SS
305x35x20 is 28.4"
And since diameter is a full measure of tire height, that 3/4" difference must be cut in half, since half of the 3/4" is on top of the tire and the other half is what is contacting the ground. You're close to 7/16" difference from stock. Not significant.
2018 Red Hot 1SS, GM lowering kit & 1LE Sway bar kit, ZL1 1LE solid rear cradle bushings, BMR sway bar end links, GM CAI w/tune, Pray ported IM, Mamo ported TB, VS Forged VS07 rims 20x11 & 20x10 w/ Michelin PS4S
Shawnqa800720 is offline   Reply With Quote
