#15 | |
![]() Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
Any other options other than adding a signal processor after the Bose amp, new amplifiers and new speakers? Maybe a passive crossover and small tweeter added to the corner Bose speakers? |
#16 | |
![]() ![]() Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
You could always add a passive crossover to eliminate those frequencies. jax_Chris may chime in with a suggestion also
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK ![]() |
#17 |
I was thinking more in the line of keeping the Bose driver, adding a high efficiency tweeter (don't yet know where it would fit) and splitting the signal between the two with the crossover.
#18 |
![]() ![]() ![]() ![]() Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
It's rare for someone wanting to add more tweeter to a factory premium system. I'm always very sensitive to stacking too much tweeter in a system -- especially hard metal domes. If you want more tweeter, much sure they are soft domes. Titanium tweeters make me feel like someone is drilling my skull.
Are you just wanting a drop-in speaker adjustment to the Bose system, without new amps or extra processors? Matching up the low impedance of the Bose speakers is going to be tough to keep the same juice to the cones. If you care more about SPL, then 90+ SPL speakers at 4ohms should run on the Bose amp just fine (as long as you replace them all with the same resistance, I don't know how many posts are in the amp or how the channels are paired to them). You'll lose half the wattage going to 4ohm, but a very sensitive speaker should give you all the nuances you're asking for. If you want to recover some bass, I would suggest throwing some 1-channel mini class-D's in the door panels and driving them off of the window motors so you don't have to modify the doors bulkhead connector. If it is 10amp, you can run them with the windows, if they are 15amp, then mute/turn down your radio before operating your windows. Alpine, Clarion and Kicker each make palm size 1 & 4 channel class-D's that run at 4/2ohms. The Alpine isn't sealed for outdoor use, so using that in the door panel might be a risk. You'll also want to take measurements and scout your possible install locations before deciding on which amp. Space and location could dictate which amp you use. |
#19 | |
To my untrained ears it just sounds like the system trails off at the high end and needs some help above 10k Hz or so. The other issue is: how much is the amplified signal to those speakers modified from flat to make up for inaccuracies in those small Bose drivers? Would flat-response drop-in speakers sound worse? That's why I thought keeping the Bose, splitting the signal through a (8k Hz?) passive crossover, and adding separate tweeters might add some sparkle to the high end without messing up the rest of the response. Thoughts? |
#20 | |
#21 |
The Bose drivers actually aren't terrible. If you just want speakers, test out the Bose first. Get yourself a pink noise tuning app on your phone, sit in the car, play the track and then tweak the factory 3 bar EQ to pull down the treble and bass until midrange shines. Then bring the bass up until you're happy that it too isn't muddying the middle. After that, you just use volume control.
The Bose amp is designed to output at 2ohm. If you throw 3.5 or 4ohm speakers into the system, you're going to cut power and possibly cut down the output to half which means the amp runs hotter to displace the energy it isn't sending down the outputs. Pretty sure the front of the car is on one pole in the amp and all of the rear is on another pole. If you put a single 4ohm speaker in the front of the car, you'll cut power by half for all of them. The PAC or Axxess integration modules plus a few cheap mini class-D's will provide the same power level you're used to at a 4ohm load and let you use whatever size speakers you can find. When not matching up subs, I would much rather start with a 4ohm standard system. It's like trying to mess with a 3-way component and keep the load at 4ohm across the range. If your driver is going to overlap with your woofer or tweeter, then you need to lower the resistance of the driver to make it the path out of the passive crossover that gets the midrange signals. A 3.5ohm driver will pull the power of a frequency before a 4ohm driver will on the same collective circuit. Electricity is funny like that. If any things are not equal, then everything gets very complicated. That's why even budget builders eventually look at going full 3-way active on their front stages so they can run each speaker on its' own without juggling anything. With modern car audio factory "premium" system replacements, I wish there were just decent priced 2/3/4 channel amps with 2/4 input modes, great bandpass capabilities and a small footprint. Stick them behind a half-assed integration module with beginner friendly DSP functions and most people that post in here would have what they want without costing a crap load of cash. |
#22 | |
#23 |
I looked all around today and couldn't find a good option for the dash corner speakers for a budget upgrade.
Drfeelsgood spent a lot on those HAT 2.7" drivers and I'm sure they are great, but that is more than even I would want to spend. (your post was the first I heard of them and I had sticker shock when I saw the prices on them haha) OP: The problem with getting any ~2.5" speaker to fit there (and why everyone is just dropping tweeters from 2-way components up there) is that the mounting depth is only 1.3" and the top clearance is only 0.2", making it a VERY tight fit. If you look at the factory Bose speaker, it uses a wide and thin magnet where most drivers under 3" would typically use a neo magnet which needs more depth than the pancake Bose put on that speaker. I believe that speaker is a one-off just to fit what Bose recommended into the space that Chevy left behind. If Chevy had provisioned the center channel pocket for two 3" drivers, the corners could've held the tweeters and some faux-center imaging could've been done without doing such a weird speaker in a tight location. |
#24 | |
![]() Drives: 2017 Camaro V6 1LE Join Date: Jun 2017
#25 | |
Let's assume for the moment I just don't touch the tweeters because problems laid out by JaxChris. Just in reference to the door/rear monitor units. Last edited by 302Blue; 01-09-2019 at 02:36 PM. |
#26 | |
#27 | |
#28 | |
| Tags |
| bose, dynamat, replacement, sizes, speaker |
