#15 | |
![]() Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
https://www.borla.com/products/camar...rt__60606.html And it says it's been discontinued. |
#16 | |
I also way back when the 6th gen first came out had CA front cat deletes. the low speed drivability was not as bad as headers, but there was a strange exhaust resonance at 1200 RPM or so, so I think 6th gear was more usable but not great say 62 MPH or so. I lived with no cats for 2 years, the car is SO much better of a street car with cats. I would never go back. I had always intended installing the high flow cats or cutting and welding back in the stock back two cats. Autos don't see to have any issue at all. .it is the 608 that has mufflers in it BTW. https://www.jegs.com/InstallationIns.../157-60608.pdf called a "touring resonator"
#17 | |
![]() Drives: 2018 Camaro SS Join Date: Feb 2016
Ah that's too bad. I wonder why. Do you know of any other alternatives?
Current - 2018 Camaro 1SS with MRC, 1LE Suspension, NPP Exaust, 6 Speed.
Past - 2016 Ford Mustang GT Performance Pack 2015 Camaro SS 2010 Ford Mustang GT |
#18 |
![]() Drives: 2017 Camaro FIFTY 2SS Join Date: Jan 2017
I am going with the Stainless Works axle back and AFM and NPP for $1700 shipped. I wanted to keep both functions of the exhaust, but could not justify spending any more than that.
I hope the drone is not as bad as people say, but I have heard its not bad at all on the A8 for some reason. |
#19 |
probably the AFM. Also depends on the street speed, most county roads here are 65 MPH, so with no cats I had to get to 67 MPH to use 6th gear, as soon as I dropped below that I had to use 5th... Probably people on an auto don't even notice, but on a manual you have to shift. The AFM must also be effective too. I lived with it for 2 years, but with cats it is near stock in drivability. I could have put small bullets in my original Kooks cat delete pipes. But plan to put cutouts in them now that the cats have solved all drivability issues and cutouts is going to let the street scene the Oldman is all business....
I had stainless steel works on my Challenger. Nice stuff.
#20 |
![]() Drives: 2018 2ss 1le Join Date: Jan 2018
I'm doing stainless works... 1 7/8 into their 3" x pipe with cats this system ties into stock npp...
we will see but I think this might be the best solution for drone / power / driveability |
#21 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
Mph
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
#22 |
dunno, what the minimum MPH I can do in each gear; now as most of my driving is WOT, hence the need for the 4th set of rear tires in 18,000 miles. that said, what I posted is about what I do now with LT, cats and factory cat back. bout 52ish in 6th...
For sure because I have it memorized, with LT no cats, 6th can't be used till 67 MPH.
#23 |
![]() Drives: 2018 SS 1LE Join Date: May 2018
I’m going full ARH as I not only want the louder car but am looking to drop as much weight as possible. Best guess on info from ARH is you’d drop 40lbs+ off the car by doing the full system. Comes at a cost but I’m only doing exhaust once
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl |
