#15 |
![]() Drives: Currently Looking for 2019 SS Join Date: Dec 2017
#16 |
![]() Drives: 2016 Camaro RS Join Date: Sep 2016
Mine also stays on every once in a while and I also just disconnect the battery terminal. But I wish I knew what what was causing the issue
#17 | |
And this got bumped up to a case with GM? And why, if the coolant thermostat is stuck open (and the coolant therefore always cold), would the cooling fans stay on??? Most fan modules now sense the radiator temperature and adjust the cooling fan(s) speed(s) accordingly. In cold weather, the fans might not even come on for a while. The exception is typically for A/C, where the fans automatically go to high speed when the A/C is active. Just hope it all works for you now. |
#18 | |
figured I'm still under warranty, easy fix and I'm covered but took them a week. I just hope this was the issue and it doesn't come back |
#19 |
![]() Drives: 2016 Camaro LT Join Date: Aug 2018
Hey, I'm having the same issue with my 16' LT. The dealership ended up replacing my thermostat housing unit and was working fine for about a month and now its back to being stuck open (even with the new thermostat). How has your car been running since they fixed it?
#20 |
Mine did all those things to and I ended up replacing the coolant temperature sensor last week. Hasn’t happened since. Fingers crossed though!!!!
#21 |
![]() Drives: 2016 V6 Summit White/Adrenaline Red Join Date: May 2016
Update on this? My car has been doing the same thing
#22 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
If the ECM sees an issue with knowing the engine coolant temp, it will command the cooling fan on all times as soon as the car is started. Circuit concerns, inoperable parts, extensive leak - whatever. Just an FYI.
#23 |
![]() Drives: 2016 Camaro 2SS Join Date: May 2016
Just an FYI for future searchers...
I also had the “fan stays on high and temp gauge on 0”... No check engine light on. Fan would run full speed for 10-15 mins after the engine was shut off. After driving the car for an hour, I noticed there was no pressure on the upper radiator hose, this led me to believe the engine really was running cool. I pulled out the thermostat, it appeared to be stuck open slightly. So I got a new stat, compared/measured them and the original stat was open about .060” or so. Not much, but it was enough. Changed the stat, cleared the two codes it had stored (p480/p691). Started it up and within 5 mins was showing some temp on the temp gauge and the fan was not running. So in my case, it was NOT the coolant temp switch. The car is bone stock and has 51k miles. Afterwards, I boiled the old thermostat, it opened WAY up and stuck there. Even freezing it, it would not return to close or even move at all... Thermostat was $120 at the dealer and it was in stock.
#24 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
whats the part number on the stat
#25 | |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
Long ago I got in the habit of testing new T-Stats out of the box & test once a year. People would be amazed at the actual failure rate. Most times it was a binding in the shaft or a spring rebound/ tension issue. I’ve noticed from time to time my car having the fans stay on after shutting it off. My plan is to start some diagnostics this spring when & if it reoccurs. |
#26 |
#27 |
#28 |
Pills are for Pansies
Drives: 2023 2SS Red Hot Vert Camaro Join Date: Jul 2008
Mine just did this. Fan stays on, check engine light on and temp gauge not moving from 0.
This extended warranty from ally better cover it. |
