Old 11-25-2018, 03:43 PM   #15
VinnAY
Drives: 18 1SS/1LE
Drone has a lot more going on with folks that insist on being in too high a gear and running the engine RPM in the dreaded 1500 range. But you can't tell em to downshift they'll insist it's the exhaust and that they should be able to run it in 6th @ 45mph
Old 11-25-2018, 06:27 PM   #16
ANGRYSS
ANGRYSS's Avatar
Drives: 2018 Camaro 1LE
Same thing with the skip shift. If you shift like you should that never comes in to play.
2018 Camaro 1LE
Nightfall Gray Metallic
ANGRYSS is offline   Reply With Quote
Old 11-25-2018, 10:14 PM   #17
MAGAUSA
MAGAUSA's Avatar
Drives: 2017 Hyper Blue 1LE
Originally Posted by ANGRYSS View Post
Forgot about secondary cat delete. Usually headers are the first mod to go on my cars but since this one is brand new I have been holding off on that for a little while. Thanks for your input it is much appreciated.
If you'll be otherwise stock after this axle back, you could open it up more if so inclined with a decent midpipe which deletes the second cats. That's if you want more volume. I did this with stock NPP and it was like getting a new exhaust.
MAGAUSA is offline   Reply With Quote
Old 11-26-2018, 12:08 AM   #18
Ghost18ZL1
Ghost18ZL1's Avatar
Drives: 2018 ZL1 1LE
I have a B&B bullets on my C6 and absolutely love it. Looking for a similar sound for the 18 1LE...any suggestions. The louder the better.
Ghost18ZL1 is offline   Reply With Quote
