#15 | |
![]() Drives: 2016 NFG SS A8 Join Date: Jul 2014
2016 NFG 1SS A8. Pray ported intake manifold, Rotofab dry cai, kooks 2" catted longtubes, E85,
#16 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
The publication haven't really gotten representative time for the SS A8 however. Our fast list has an average of 12.0 to 12.1 depending how you slice it (see link). https://www.camaro6.com/forums/showp...9&postcount=49 As you mention, M6 are 2 to 3 tenths slower so its possible. Even Chevy rates the M6 as 2 tenths slower
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
#17 |
@OnThreeSS
Drives: 2016 Camaro 2SS Join Date: Dec 2018
I heard the A8 was a tad quicker than the new A10
#18 |
Moderator
Given that the new SS A10 has a lower torque rating than the A8, there may be more torque management at play, so a slightly slower time wouldn’t surprise me.
#19 |
It's because the SS A10 is a 80 series rated for 80 newtons. The A8 is a 90 series just like the A10 in the ZL1. It has been mentioned the SS A10 shifts much firmer then the A8 so I am not sure there is more TM at play.
#20 |
It may be a long time before we find out. These 19’s are just not selling at all. The one acceleration video I did see sounded like a lot of torque management on the 1-2, 2-3, and even the 3-4 didn’t sound as quick as the A8. This too is the reason I think the new mustang is a hair faster stock. They have a drag mode that eliminates all the torque management. If we had that option, we would be so much faster stock
#21 | |
Moderator
#22 |
I'm not so sure about that...both the 80 and 90 series have much more capacity far as handiling power then a stock LT1 can dish out.
The torque management is in place to keep the car in control and to protect the trans. If GM shipped the A8's out with the ability to turn it all off, there would be a lot of 6th gen Camaros ending in the ditch with the run flat tires. The car will get sideways on a gear change with No TM, compared to being on, where the ECM will pull torque on the shift so the car will quickly recover from spinning the tires. I have spent a lot of time over the last year tuning and playing with the TM. Imo the TM is harder on the transmission in some ways....especially when you mod up and increase power. The TCM needs tuned properly. I'm not saying you should turn it all off, but it needs to be reduced significantly. The shift time, inertia, and pressure all needs adjustment as well.
2016 NFG SS A8/Whipple 2.9/Fuel System/Flex Fuel Last edited by KingLT1; 12-18-2018 at 12:57 AM. |
#23 |
![]() Drives: Camaro Join Date: Sep 2018
#24 |
![]() ![]() ![]() Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I wonder how much different in stall speed the torque converter is? I think that will make the best difference, and the fact if it has to do another WOT shift in the 1/4mile. Well the biggest difference might just be weather the TCM is programmed to shift at the correct WOT shift speed. My A8 short shifts, especially on the 1-2 at about 5500rpms.
#25 |
![]() ![]() ![]() ![]() Drives: 1LE Join Date: Sep 2017
#26 |
![]() Drives: 2023 Silverado LTZ, 2022 Camaro 2SS Join Date: Jul 2010
2019 Bone Stock SS A10
DA -435
Currenent rides: 2020 SW ZL1 A10 2019 SW 2SS A10 2017 SW Silverado LTZ |
#27 |
That A10 pass is so close to my stock A8 pass of 12.04@115 a few years back. Great pass
#28 | |
Car was pretty consistent. Ran 12.00, 12.01, and 12.03. I tried leaving at 1,500 rpm and the 60’ slowed to a 1.82 from a 1.80 on the 12.03 pass.
