#15 |
![]() ![]() Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
It's not, I've done my transmission 3 times. It takes just under 4 qts to start getting it to leak back out. Then you remove the 240ml and you're set.
#17 |
![]() ![]() ![]() ![]() Drives: 2020 ZL1 1LE Join Date: Sep 2012
You may still see a teaspoon or so if you get it hot. Typically only occurs on the track for me when the temp goes above 200F. It will stop once it equalizes.
#18 | |
![]() Drives: 2018 Hyper Blue Metallic 2SS 1LE 6M Join Date: Nov 2024
I just did mine today. Drained from the temperature sensor. It took under 4 quarts. |
