#15 | |
Looks like the 285/35s would fit on the stock rims and be about stock diameter! Humm
#16 |
![]() ![]() ![]() Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
I have zl1 wheels. I am running 285/30’s on front and 305/30’s on back. To switch to the 305/35 MT’s, I also need to go with a taller tire in front. Planning 275/35’s.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
#17 | |
That means I won’t need to get new front tires...anyone know if I still have to move the wiring harness on the 315/30’s? I like not having to trash my existing front tires.
#18 | |
![]() ![]() Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
Definitely need to move the harness and I hear some say you need a 5mm spacer. |
#19 | |
Ok so my front 555G2 Summer tires are 27.56. They are 275/35's. Will they work with the Nitto 555r's @ 28.58 diameter - 305/35? When I first got my wheels I started off with 555G2's front and rear. 305/35 Rear and 275/35 Front and it gave that Stablitrac a FIT. I had to replace the rears to 305/30 to resolve that issue. Rear 555G2's are 28.41 Diameter so if the Drag Radial is 28.58. I may likely run right back into that nightmare.
#20 | ||
Point being different tires may squat more or less depending once installed on the vehicle. I would measure both the front and rear while on the car to see actual difference. Off the top of my head I think you will need a different tire up front or get a R888r in a size that works.
#21 | |
I am so confused. When I go looking at threads about tires, it’s like from one thread to the next there is just so much information that contradicts the other thread. Advantage of the 315/30, I shouldn’t need to get rid of my ggg2’s on front (have about 2000miles on them...Toyos are probably not the best in terms of strip...but better on street. If I go with new front and back, then either MT’s or Nitto 555R are viable options. I was told we would need 275/35’s and 305/35’s. Neither will be as good all around handling as the Toyo, but could use either on the strip.
#22 |
![]() ![]() ![]() Drives: 2016 Camaro SS Join Date: Sep 2018
I've had both as well and had a different experience. Maybe our streets are paved with different materials.
#23 | |
![]() ![]() Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
#24 | |
Here is a good link: https://www.camaro6.com/forums/showthread.php?t=540052 Most likely the car is in the garage until the new hood or chin splitter arrive.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance Last edited by Drsagacity; 10-31-2018 at 11:44 PM. |
#25 |
Huh.
#26 |
I’m thinking that I may have to tune on dyno, the car can’t hook at any legal speed, and this is before E85.....
#27 |
![]() Drives: 16' Camaro 2SS Join Date: Sep 2015
Must have some really cruddy tires then :( Regardless, dyno is 100 times safer and more consistent for tuning anyways.
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R 9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp) |
#28 |
true dat, So is there any dyno tuner in Austin area that are known? I know there are a few in Dallas and 21st performance comes to mind, a few more in Houston and I've heard of one in College Station. Still I'd like to keep to maybe College Station as the furthest, or San Antonio.
