Old 10-21-2018, 10:09 PM   #15
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Arp bolts normally are reuseable.
Old 10-22-2018, 02:20 PM   #16
djfury05
djfury05's Avatar
Drives: 2017 ZL1 A10
Originally Posted by zepol9 View Post
It came as 2 pieces
Yea I'm aware of that. You should be assembling the hub to the balancer before installing on the crank.
djfury05 is offline   Reply With Quote
Old 10-22-2018, 02:46 PM   #17
oldman
Drives: SS 6 speed of course
you need to use the AutoZone Chrysler damper installer! It pulls from the inner spokes.
https://www.autozone.com/loan-a-tool...ler/391370_0_0
Old 10-23-2018, 02:53 AM   #18
zepol9
Drives: 2016 Camaro 2SS NGM
Look at this
zepol9 is offline   Reply With Quote
Old 10-26-2018, 10:00 AM   #19
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Here is what i did.. I used the rebranded whipple balancer by ATI.. I used a impact wrench to remove the bolt but you have to remove the fans to fit.. I used an old bolt welded to another bolt and a big washer and nut to draw on since the new bolt shouldn't be used to pull it on.. and the original bolt is to short..
If the flywheel moves try these tactics.. You can also use the impact instead of torque wrench but u need to know your gun well so you can get close to the torque!
https://www.camaro6.com/forums/showthread.php?t=517100
Or All Girls Garage on wifes car used a special tool on starter flywheel.. minute 6:50
Or you can pull the tranny off and use one bolt hole from flywheel and 1 bolt hole on clock with a bar that has hole drilled in it for the bolts to pass through holding the flywheels still. minute 11:30
Old 10-27-2018, 12:30 AM   #20
oldman
I estimate it is 190 ft lbs for 90 degrees
