#15 |
![]() Drives: 2018 Mosaic Black Metallic ZL1 A10 Join Date: Sep 2017
I did Eibach and the mechanical platform is way more level at VIR than the stock springs. Very happy I had them switched although I wish the rear was about .5” lower.
#16 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
#17 |
![]() ![]() ![]() ![]() Drives: 2018 ZL1 (SOLD) 992 GT3 (current) Join Date: Aug 2013
Apparently Moreno camber plates give the option of lowering the front of the car by 1/2"
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
#18 | |
If so, how much did it lower your car by? YYZ says it drops the 1LE by 1 inch, but I'm not sure if that would be the same for a ZL1 since they have different springs. I've contacted them and am waiting to find out. Another option is Down Sus RS-R lowering springs, their spring rates are only a little higher than stock (about 5% to 10% more) and they say their springs lower the camaro 1" to 1.2" but they don't specify if that's the SS, 1LE or ZL1. Again I'm waiting to find out from them.
#19 |
![]() Drives: 2019 ZL1 Crush Join Date: Jan 2019
If you can find them, Swift makes really good springs as well.
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
rennick sells em made by swift but i like my powell yyz springs made by hyperco better https://www.renickperformance.com/
#21 | |
#22 | |
#23 | |
I'd go with Eibach except I've heard too many guys with 2018 ZL1's say it hardly lowered the car.
#24 | |
Also says it will lower a Camaro by 20mm (about 3/4" to 7/8") but doesn't specify which model of Camaro or what spring rate the springs are
#25 |
my car is a 1ss without magride and yyz springs lowered my car about 1" around mrc will be around 3/4" and zl1 might be less or same
#26 |
Thanks
#27 |
#28 |
not true...my car is a '17 and it sits perfectly now. I would not want it any lower. Fanatic's car is an '18 and his car is slightly higher in the rear for unknown reasons.
