Old 10-12-2018, 03:34 PM   #15
evonschu
evonschu's Avatar
Drives: 2013 Camaro ZL1 M6
I have a 5th gen ZL1, but have Alki 5 Gallon Meth kit. I usually get about 3-6 months on a tank with normal driving around town and getting on it somewhat frequently on on-ramps and the dumbass Subarus around Portland trying to race me.
Honestly, one thing to think about that I didn't consider is that the internal gaskets in the pump motor on it will start to leak after 1-3 years, maybe longer, from the corrosive nature of the Methanol. Not sure on other kits but mine started leaking and I had to unbolt it and send to Alki to refurb. Guess its a common thing for it to not last long. He did it for free, but not happy that I'm going to have to deal with that pretty frequently. I made a custom tray so when it happens again it won't soak the carpet in the trunk.
It is a trade off though as IAT2 temps are low even after several pulls. However, I question how much of that is from Meth vs the heat exchanger + rotofab extra coolant tank.
2013 Camaro ZL1 M6: Rotofab CAI, JDP ZL-R Rough Idle Cam, Upgraded Valve Springs and Pushrods, Ron Davis Heat Exchanger, Alky Methanol Injection, Rx Catch Can, 87mm VMAX Ported TB, Summit Performance Spark Plug Wires, 10" Lower Pulley, Kooks 1 7/8" Headers with Magnaflow Cats, ID850 Injectors, Johnson 2110R lifters, EBC Slotted Rotors+Hawk Pads, Rotofab SC Coolant Reservoir, 160* Thermostat, Custom Mild to Wild switch, Tune, 1st to 4th bypass. 685 RWHP / 640 RWTQ.
evonschu is offline   Reply With Quote
Old 10-12-2018, 10:09 PM   #16
Markoz28
Drives: 18 ZL1 nightfall grey A10
All of this is good info. I just need to figure out which kit to get.
Markoz28 is offline   Reply With Quote
Old 10-12-2018, 10:21 PM   #17
laynlo15
Drives: 2022 Lt1 A10
You don't need to remove it unless your going to use the Washer Tank. If your going to mount the tank in the trunk you can mount it in the engine bay, trunk or where ever you want. I just like it because it only has to travel a few feet to the elbow where the nozzle is plumbed. If the tank is in the rear it is 15 feet and remember you just have a very small line that has to be run from the trunk to the front. Also if your running Meth in the trunk it has to have a firewall separating the tank from the interior since it is flammable.
Old 10-12-2018, 10:24 PM   #18
laynlo15
Meth does have some cooling effect but water mixed with the Meth is a much better cooling agent then straight Meth. Meth works as fueling more then cooling since it evaporates rapidly and that's why I run both.
Old 10-12-2018, 10:38 PM   #19
BMWM.D.
BMWM.D.'s Avatar
Drives: ZL1/335i
Yeah, that’s what I meant. I also like using the washer tank for the same reasons. I’m not sure I want to remove the wheel liner to do it on this car, but it’s still a better option than a trunk mounted tank.
BMWM.D. is offline   Reply With Quote
Old 10-12-2018, 10:39 PM   #20
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Water has a lot higher latent heat capability than methanol for sure. I’d recommend 50/50 water to meth mix. That eliminates the fire hazard too...
Old 10-13-2018, 05:20 AM   #21
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
I am fascinated with the idea of running Meth but know little to nothing about it and afraid my limited knowledge and assumptions probably have kept me from ever using it.
For example. How can Meth be used as a non-fuel? only for cooling? I thought meth even mixed with water still had some fuel like benefits and ultimately is there ever a way to tune a car with meth that doesn't result in that Single point of failure that could cause engine damage?
Dysan911 is offline   Reply With Quote
Old 10-13-2018, 06:25 AM   #22
laynlo15
The line is pretty easy to drop down. Might take 15 minutes. Then you have to tap into the washer tank which set down low at the back of the fender well.
Old 10-13-2018, 06:29 AM   #23
laynlo15
Meth is the fueling, water is the cooling, together they work the best. Meth will have some cooling effect plus adds fueling.
Old 10-07-2023, 07:58 PM   #24
UberTong
Drives: Chevy Camaro ZL1
Originally Posted by Markoz28 View Post
Awesome! Thanks for the reply’s.
So does the nozzle connect to the intake elbow before the throttle body?
I have it on my ZL1. It’s the first vehicle I’ve owned that used methanol. I will say this, it’s strange but I like it. I don’t know if it’s a placebo effect but when you REALLY lay into the loud pedal it makes a world of difference. It almost feels like the top end just gets way more oooomph. It’s not bad on price either, but I guess that’s all relative. I just went to the local performance store and paid $55 for a 5 gallon drum of VP pure grade A M1 Methanol snake oil. 😂
If I had a gun to my head - I’d say do it. It feels like my old car and the difference between pump gas and E85. That’s a good analogy. PFA
UberTong is offline   Reply With Quote
