12-27-2018, 09:19 PM | #15 |
DWR, I wish you luck in you’re wanting GM to pay your payments while the car was in the shop! I had 2 fuel injectors go bad on my ‘16 and replaced in October under warranty. Had 2 codes popping up and it took a couple of visits to the dealership for them to diagnose the problem. It runs like it did when it was new now and everything seems to be good to go. Guess the tech was one of the best at the dealership.
12-27-2018, 10:42 PM | #16 | |
Drives: 16ss, Ram, r32 Join Date: Feb 2018
Second one has had pistons head cam etc... Just 2 engines so far. Including the original. My car shakes under load or when cruising. Main harness has been replaced as well. The list goes on. 🤦🏾*♂️ |
12-28-2018, 06:48 AM | #17 | ||
Drives: 2018 Camaro SS 1LE Join Date: Jul 2010
I've read a couple other users on here that have managed to get them to do it (when it has been an extended time period like mine) so it is possible at least. I'm glad you were able to get your issue resolved easier than I did!
2007 Colorado I-5 3.7L z85 2wd ext. cab --Totaled 2004 Silverado single cab 4.8l v-8 2wd -- Traded 2018 Camaro SS 1LE -- Current DD |
12-28-2018, 06:51 AM | #18 | ||
Geez... Tell them about the bearing is most likely spun; if they wont tear down to check then call GM corporate and explain the issue and how me having the same issue turned out to be a bearing.... If you would like I can give you my info (in private message) so you can reference my exact case.
01-26-2021, 03:39 PM | #19 | |
Drives: 2019 Chevrolet Camaro ZL1 Join Date: Mar 2020
01-26-2021, 06:19 PM | #20 |
Drives: 2020 lt1 gone: '14 2ss,16 2ss vert Join Date: May 2009
"found that it had spun a main rod bearing."
So was it a rod bearing or a main bearing? |
01-28-2021, 11:30 AM | #21 |
Drives: 2021 C8, 2022 Camaro 2SS Join Date: Jul 2015
Image below should answer your question:
Order 9/09/2021,2022 2SS, NPP, 56W whls, B04 stripe, AQJ seats, N26 strg. whl., SLN brace
3000 1/19/2022 3400 1/25/2022 TPW 1/31 3800 2/15/2022 4300 2/19/2022 4B00 3/04/2022 4000 3/8/2022 Delivered 3/9/2022 ____________________________________ Order 6/01/2016 2017 2SS, NPP, 56R whls 3000 6/08/2016 3000 6/15/2016 TPW 7/18/2016 3400 7/7/2016 4200 7/25/2016 Delivered 7/28/2016 Sold May 2020 |
01-28-2021, 09:41 PM | #22 |
nice image but it doesnt answer the question. just never heard a rod bearing referred to as a main rod bearing before. usually a main bearing is the main bearing, and a rod bearing is the rod bearing.
