Old 09-24-2018, 11:00 PM   #15
oldman
Drives: SS 6 speed of course
ZL1 has same exhaust as the SS, so stock is pretty good. There was a slight harmonic with front cat delete CA, much worst when I went to LT and no cats, Once I put cats on the LT with stock cat back, it is perfect. I have an M6. So IMO, all exhaust need a cat right after the header, at least for the M6. Cats really make the exhaust sound more responsive sounding. IMO I would wrap the starter because of heat, do the off road head pipes, the ones that replace all 4 cats (New Era Performance), and install, 2 high flow cats, I’d do 2 and three quarters as the factory exhaust header is 2.1 ID AFAIK. Should be about stock quiet.
Old 09-28-2018, 11:32 AM   #16
ProCharger
Drives: Many C7's
Unless you are planning on making 800rwhp or more, stick with the P-1X.
Save the $$$ and just enjoy your car making the power you want.
I have tuned P-1X cars that even with stock exhaust, stock intake run in the mid-tens.
(higher then stock boost, + meth systems)
Your goal is very very easy as long as you have the fuel there.
ProCharger is offline   Reply With Quote
Old 10-10-2018, 09:18 PM   #17
Sixgunsled
Sixgunsled's Avatar
Drives: 2017 camaro SS 1LE
whats the highest RWHP numbers you've seen with the D1X on a 6th gen?
2017 1000+hp Camaro SS
88/96 single turbo
manual to TH400 swap
15" conversion
Port injection
22K+ followers on Instagram @Sixgunsled
6.4K subscribers YouTube: Sixgunsled
Sixgunsled is offline   Reply With Quote
