#15 |
No flex fuel sensor or fueling mods of any kind? Tuned I'm hoping? This sounds shoddy...
#16 |
![]() Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
So are the injectors or fuel pump just being on the edge of not being able to run the extra 30% of volume it takes to give the full e85 a go? It works for some and not for others it seems.
I have e85 readily available and love the stuff...but having to mix them every fill up is probably a deal breaker for me. Mine measures 77% every time i test it |
#17 |
So if I go Ported ZR1 TB, Ported SC, and 60% e85 I will need to mod fueling too? No meth or pulley for me.
#18 |
Train Driver
Drives: 2018 Summit White ZL1 1LE Join Date: Jun 2013
You should be good, if you dont raise the boost on E60. Really no need to go over E50 though. Stay further away from the edge of the cliff.
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / / |
#19 |
![]() Drives: 17 ZL1 A10, BMW 1200RT-P Join Date: Feb 2017
Of course the sensor and tune...... No fueling mods what so ever. Have all the time slips. You will run out of low side with pretty much any other mods.
In the famous words of Al Bundy "Let's Rock!!"
#20 |
![]() Drives: 2018 ZL1 1LE Join Date: Apr 2018
To properly run E85 a new cam is needed.
With my; Stage 2 cam Rotofab 10% lower ARH LTH and 3” system DSX TM TB Tune Flex Fuel Sensor Lingenfelter 160* TStat C&R Racing Radiator Prospeed Large Capcity Heat exchanger Prospeed 1.5gal Supercharger Fender Tank I am making over 700Whp and 685 Ft/lbs on the CMS Mustang dyno at E80. This is with a 100% stock LT4 fuel system plus the DSX lower. |
#21 | |
![]() Drives: '19 ZL1-1LE Join Date: Jul 2019
thanks for the feedback in advance |
#22 | |
#23 | |
![]() Drives: '21 ZL1 A10 '08 SRT10 Join Date: Apr 2019
Low side is the fuel from the tank. I believe its about 70PSI on this engine, before it goes to a high pressure mechanical pump on the engine that tops out at 2900Psi |
#24 |
![]() Drives: 18 Tahoe RST, 19 Z06 Join Date: Apr 2017
To me, the switch to E85 is well worth the effort. My car made +49 rwhp on E85 vs. 91 octane. Runs were done on the same day about an hour apart. The "E85" here is advertised as 70% ethanol and is actually closer to 65%.
My car cold starts, hot starts, and drives like stock on E85. I am getting 15.6 mpg in my normal rural/city driving. That is down from about 18.5 on 91 octane. I live at altitude so I can get away with running full E85 because power output is lower here. My low side is starting to drop right before the rev limiter. A low side will be the next upgrade. |
#25 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
This is a misconception and not accurate. The ZL1 fuel system is more than enough to run E85 up to about E60 with no issues. Just need a shop that knows how to tune and can adjust the SOI and EOI. I have a 2017 SS 1LE with a Procharger D1SC and the full LT4 fuel system from tank to engine. I made over 630rwhp while running E40, I will get near 700rwhp once I put E60 in the car. As for the OP, all you need to do is call Jeremy at Skidmark garage and order his plug and play E85 kit and install it. It will take less than an hour of time, then once installed take the car to your favorite tuning shop and pay them to turn on the E85 sensor and setup the tune. Then you can run E85 or gas at your leisure. The only thing I would suggest is to ramp up the E85 slowly, start at say E40 and move up in 5 increments while logging the low and high side fuel pressure until you see it start to taper off on the high side. You will get the vast majority of the HP gains once you hit E50 or so, after that from E50 to E80 there is only about 5-10 rwhp gains left to be had.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
#26 | |
He went to a 2.1 upper, added a LPE big bore, and injectors went to 6.3ms but the fuel pressures were still solid. So the injectors were tapped at 12.5psi with E50. 2.1 pulley ended up being to small for the snout and locked up(I didn't install it), so we pulled the 1.74 blower off and waiting to install a Maggie 2300. Probably going to drop back to E40 and see where it's at and go from there. A stock LT4 should be able to run full pump E85 no problem imo if the tuning is correct.
#27 |
![]() Drives: 2017 ZL1 Join Date: Jun 2018
With the jms my high side is the weak point. 10 pounds of boost and I’m stuck at E40.
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
#28 | |
