Old 09-25-2018, 09:12 PM   #15
JRS
JRS's Avatar
Drives: 16 camaro M6/ 18 ZL1 camaro A10
Originally Posted by BMWM.D. View Post
I’d like to see a picture with that plastic cover removed.
But yeah, I did a quick eyeball of the pulley alignment a few days ago. I centered the belt line of the griptec pulley/hub over where the belt currently sits, and it sure looks like the hub and shaft should be about even. Not exactly scientific, I know.
I’m waiting to do this swap until after I get back from the drag strip this weekend. I want to see what it’ll do with stock boost first.
By the way, which belt did you use?
Here are some pic's of the pulley installed with some measurements.
I used the factory belt since it still had plenty of tension left. I would say another thing that helped is the grip tech pulley grips the belt a lot better than the factory pulley because the boost seems to be more consistent then it was before.
I went from a rough 9 psi to a strong 11 maybe 12 psi. of boost now.
JRS is offline   Reply With Quote
