#15 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
It was late, I can't read
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
#16 | |
![]() Drives: 2018 Camaro ZL1 Join Date: Feb 2018
#17 |
![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
I think there’s an understanding that the zl1 is limited by fuel but you need to consider all the variables. Such as the motor is built. Which could mean lower compression, better material, larger cubic inch displacement, forced induction, heck even the gravitation of the moon might play into it. But not everything runs the same. You have to consider all variables. Nicks car is a different animal from any stock zl1.
#18 |
Drives: ZL1 ATS-V CTS-V C7Z Range Sport SC Join Date: Mar 2016
Stock LT4 injectors are equivalent to approx 1500cc, which we all know can make 1000whp. The problem is the injection window on a DI car for when the fuel can spray. Aftermarket cams have different windows to allow the SOI to be changed.
Although the specific gravity of c16 is very similar to 93, I have seen firsthand the lackof rail drop on it vs 93 oddly; however, we all also know e85 consumes a considerably higher amount in the 30-40% range. 800+ wheel HP is very achievable on 93 with the stock high side and our low side fuel kit, the problem is the stock blower cannot reach this without being overspun to the moon, and that takes octane. With direct port meth, e85, a ton of cooling, and a 28k blower RPM, we have seen around 850whp/tq out of the stock blower, but it's on borrowed time for sure. The 103 throttlebody had such a high velocity to it that we had to have a special motor in it to keep it from fluttering and tripping CELs. I can assure you that the parasitic loss is at least 200whp with that combination as they increase exponentially the faster you spin the blower off the map. As mentioned, turbos have a much lower parasitic loss, BUT they also do not deplete the rail down low either like a PD blower. This is why you see most of these guys engine dynoing TTs with their larger DI pump and injectors as it makes the products look much more beneficial, and using MS109 vs e85 as well for a much lower fuel demand with the octane benefit. Then guys buy that and put it in a PD blower car and cannot make 1000whp because their fuel demand is instant down low and they are using pump ethanol for octane as well. So I do believe this could squeak out 1000hp, but as you can see by the AFR, the injectors aren't the issue, but the injection window. |
#19 | |
I know the oem blower is a joke but I don't want to go with a TT setup cause it's crazy expensive and complex. I wouldn't mind getting a Whipple, or even a 2300 Maggie, but I just haven't seen anyone push those to more than 700whp either without meth or cam and those should be much easier to drive and make far more efficient boost than the oem unit. Is that even possible? I just wish fuel systems weren't so crazy expensive. |
#20 |
![]() ![]() Drives: ZL1/335i Join Date: Apr 2014
#21 |
![]() ![]() ![]() Drives: 2018 ZL1 Join Date: Oct 2011
Remember he is also not running a stock engine.
2018 ZL1…Many mods to come
#22 | |
#23 |
![]() ![]() ![]() Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
- Laynlo was running over 700whp on stock LT1 with alky injection (ran over 200 times till seal failure).
- JRE super Street Brawler with 10psi is running about 750whp (700whp with 8psi)...includes LT4 fuel system and BAP, no meth. There are several guys with Maggie that are north of 700’s. Shizzy just posted over 880whp with Maggie, LT4 fuel system, 80% e85.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
#24 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
#25 | ||
![]() Drives: 2017 ZL1 Join Date: Mar 2014
Bear in mind it is also operating out of its "efficiency zone". Compressors have an ideal range where they work best. Over spinning moves the compressor out of this range. Quote:
The Hellion TT setup is ~$11K. When compared to a Whipple and headers and a cold air intake, the costs are comparable And like you, I also wish the fuel systems were more affordable. They will be in time, triple pump system were once ridiculous now they are somewhat reasonable. |
#26 | |
Curious about the other two, any build info I can read? I tried searching for them and found some posts from ShizzySupra but can't find a build thread with details. :( |
#27 | |
#28 | |
There are a handful of other guys toohighpsi was the first, but now he’s way built beyond stock, Shizzy and Stefano both have Maggie’s on kind of regular builds. There are similarly some really solid Whipple builds with big power, but no 1/4 mile times yet. Laynlo, was pushing to see how far he could take the stock motor. He ran the stock motor with alky and the big bore pump over 200 times with 1/4 mile runs. He did add the lt4 injectors this year too. He also switched to race fuel at the track...but did his stuff with the stock cam. His methanol setup was really to control IAT’s at the track where he was running multiple times. Again, your thread and comments caught my attention, so I am just throwing out some of the folks I know about. I am sure there are many others.
