#15 |
![]() Drives: Chevrolet Camaro 2SS Join Date: May 2021
Oh man this must be a wicked build!
I am doing a very similiar build to yours, and im curious to know how the car is doing months after completion? Im going 427 Darton Sleeved, f1a94, heads/cam, meth/E85/93.. and other things but I think these are the main. |
#16 | |
![]() Drives: 2017 SS Coupe 2SS 8AT (427CI, D1X) Join Date: Feb 2018
The car is doing quite well. No explosions LOL. I have the D1Xand you will have its big brother the F1A94 so you can expect to be in the mid-900 to 1000 RWHP range with a 427CI with all the internal goodies, FI tuned cam, headers, and meth injection. The one factor that is personal choice is the trade-off between maxing out on high-end HP versus sacrificing a little top end HP for low end drive-ability, a little more mid-range torque, and reliability. I opted for a mid-range cam tailored for FI -- not a peaky cam where things would bog down low and the tuner (Andrew of Complete Street Performance) and I agreed to leave a few HP at the table to have margin. I recommend you consider not going wild cam-wise -- focus on getting some torque down low since we have centrifugal not Whipple, Kong, etc. (my cam is high lift for torque but a 2 out of 4 on duration scale). I wanted my engine to be bullet proof and live at 800+ RWHP all day versus reaching another 50 HP more and being on the edge. The other thing to consider is upgrading the suspension parts to handle the power (you will see I did a lot of BMR parts and some GM ZL1 parts) otherwise wheel hop will be hopeless. Switching to a high-performance one-piece driveshaft is really necessary; over 700HP the stock shaft will likely break just a matter of time. If you can't manage the power to the ground what good is it? Finally, there is the matter of tires and rims. I went to wider rims at 10" front/11" rear with 285/30 and 305/30-20. For general street I use Michelin PS4 which some consider expensive but they offer the best all around traction and cornering but even premium wide summer tires don't do much in 1st, 2nd or 3rd with the type of power you will achieve. Drag radials are needed, either Nitto or Mickey T's for serious work on street from dig or at strip.Those are my opinions on our kind of build. Please do update me on your build. I know you will find the 427 worth it. Putting a F1A94 on an OEM block with OEM pistons and other internals would not be in one piece for very long.MJB
2017 2SS A8 Coupe w/ Leather/MagRide/Sunroof/Nav Pkg
Mod 1. Rotofab CAI, Borla S, Tony Mamo TB Mod 2 Soler Perf TB, SJM Linelock, Kooks headers, ZL1 sway bars, BMR suspension parts, Eibach springs, MRR 017 LE rims & Michelin PS 4S 285&305/30 tires, GeForce half shafts & alum. driveshaft CSP Build 1/20. Procharger D1X w/Stage 2 IC, Texas Speed 427CI long block w/forged internals/ported LT1 heads/FI cam, LT4 HPFP/injectors, ATI balancer, MM catch can, FTI torque converter, CSP meth injection & aux fuel, Aeroforce gauges, MSD wires, race BOV, PCM/TCM tune. |
#17 | |
How would you rate the daily drivability of your badass camaro? I know its a dumb question lol, but I do plan on driving mine around quite a bit |
| Tags |
| 2017 camaro ss, 8at, csp build, mrr wheels, procharger p1x d1x |
