#15 | |
Drives: 17 SS 1LE | 07 S2K Join Date: Sep 2017
Different strokes, but I'd reseat it all and check all tolerances to avoid future complications. You can't do that properly without disassembly. |
#16 | |
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
Does anyone know how much approximately a shop would charge for all of this? $1,000? $2,000? $5,000?
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 |
#17 | |
SABIO
Maybe someone could actually answer.
#18 |
![]() Drives: 2017 Camaro 1SS M6 (SOLD) Join Date: Oct 2016
For drop in pistons and rods, i would say 4-5k. Best way to find out would be to get a quote form the shop you would like to do the work.
Stock: 416hp/427tq, 12.21 @ 116.80 Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft. Tuned by EFX Tuning 688hp/632tq Best 1/4 to date: 10.705 @ 131.92 |
#19 |
![]() Drives: 2017 2ss, m6 Join Date: Jan 2017
To do it right you will want to find a high end shop that will do the needed bore and or hone with the specific finish required for your ring selection. They also need to do the math and get the piston to wall clearance set up to deal with your temperatures as well for everything to come out right. You'll want to provide them with the cylinder head mounting hardware prior so they can torque a deck plate on it while doing the machine work. Also, talk with them honestly about your usage so they can set your ring end gap properly. If that all happens the rest should be fairly straight forward.
#20 | |||
![]() Quote:
2016 Camaro 2ss
#21 |
Parts and labor, just a rough guess from what I have seen.
#22 |
That helps a great great great deal...thank you very much.
2016 Camaro 2ss
#23 |
![]() Drives: Fireball 700 Join Date: May 2017
