#15 |
![]() ![]() ![]() ![]() Drives: ZL1 1LE Join Date: Oct 2016
I currently use a nice set of MACS wheel tie-downs. I keep the front ones straight and cross the rears. Holds the car perfectly with limited inner/outer pressure on the front wheels and tie-rods. No issues with alignment yet.
I had the ZL1 tie-down points, used them once and haven't since then. The rears came loose, and the location of the front ones is impossible to actually reach.
#16 | |
![]() ![]() Drives: ISO ss 1le Join Date: May 2018
Nice, Macs makes good stuff. I need a new set of ratchets, my smart straps are getting old. |
#17 |
![]() Drives: 71 Camaro SS - 17 Camaro SS1LE Join Date: May 2011
Man - you SUCK!!! I have an H&H tilt bed and it has been great, but it is too steep to load the 1LE without using Race Ramps to help decrease the angle. I don't think MaxxD offers a wood floor option. Unfortunately, I use the trailer around the property to haul mulch, rock etc. That absolutely destroys a nice steel floor. Also, my trailer has to sit outside. I've done a ton of emergency rescue missions and need to get the trailer out at a moments notice. I can put it in the basement, but if the yard is wet or snowy, I can't get it out. That MaxxD is a sweet piece!!!
79 Camaro RS (my first Camaro)
71 Camaro SS 94 Camaro Z-28 (sold when gas hit $4/gal) 14 Camaro RS (gone - totaled by 8&9 year olds) 17 Camaro 1LE HBM Ordered 02/21 Built 4/24, Delivered 5/4 |
#18 |
Sound like I'll be adding additional E Track and getting the Macs tire straps with idlers. Not cheap and it's been so long since I've done any racing, my helmet is out of date - so add that to the list.
#19 |
![]() Drives: 2018 ZL1 1LE Join Date: Aug 2017
I got mine from Autohaulersupply.com around $30.00 each. Go into the car hauler section.
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Ya very nice trailer but nothing beats this one
#21 |
You guys are talking about two different trailer manufacturers.
![]() You got that right, but with that comes the 10k+ price |
#22 |
![]() Drives: ‘17 1LE, ‘17 BMW 340, ‘18 F-150 Join Date: Nov 2017
So there are no slots in the frame on the Gen 6 cars for a t-hook?
2017 - SS 1LE
2015 - 2SS, RS, NPP, 1LE - Sold |
#23 | |
I recently started using some hooks from Rennline which work very well. The rear one bolts right into the steel subframe bolt, and the front does the same. I did a 1500 mile trip with them on the car and they stay consistently tight. The rear ZL1addons seemed to come loose, not to mention unless your D rings are not almost directly behind the hooks, you’ll rub your straps on the exhaust. |
#24 |
Of course everything on this damn forum posts upside down lol.
#25 | |
Because Racecar!
I use the MACS straps too. Have used this method many times for both track car (1LE) and rally car (STI). My trailer is also just barely wide enough for the 1LE. roughly 3/4 an inch gap on each side. Slow and steady with a winch is the ticket imo. Have seen no change in specs in either car. I assume the track loads are much higher than hand tight trailer straps anyway. |
#26 | |
2017 - SS 1LE
#27 | |
![]() ![]() Drives: A few Join Date: Oct 2017
Since I know the approx gap I'm just keeping to close on the side with the camera. My trailer does have ~6" vertical "walls" around the sides and front so the car won't fall off.. but a wheel might suffer if I screw it up. I plan to load/unload with my original set of 1LE wheels - one has a chip so screw them all! ha
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback Too many cars.. never. |
