Old 11-10-2018, 01:25 PM   #15
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Originally Posted by SteveFrench View Post
Didn't they say in the other thread you had to remove the exhaust, and drop the trans to install it? or am i mistaken?
The instructions for the shifter install are here: http://files.dpbrands.com/hurst/inst...ns/3916047.pdf
I think the other guy you quoted was referencing swapping out the white ball upper stick for the stock knob upper stick only - he already had the hurst shifter installed. The upper stick can be installed from above. However, the entire shifter requires the exhaust and driveshaft to be removed and the transmission lowered ~3" in order to remove the old shifter and install the new one. If interested, I documented the install on mine in this thread: https://www.camaro6.com/forums/showthread.php?t=521320
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 11-10-2018, 01:39 PM   #16
SteveFrench
SteveFrench's Avatar
Drives: Summit White 2018 SS
Oh okay that makes sense. I would love to install one of these but that just seems like soo much work for the 40% reduction i want I will put it off for awhile and maybe ill cave and do it eventually.
SteveFrench is offline   Reply With Quote
