Old 09-18-2018, 10:09 AM   #15
Drsagacity
Drsagacity's Avatar
No... I just figured it using a calculator with the same formula that you program the channel to use. I found peak tq and hp from a wot log and plugged the delivered engine torque value in the formula.
Here is what I see from HP tuner from my dyno run. You can see if you add the channels to HP tuner, it will basically create a torque/HP curve just like the dyno. This was on the run that showed 705whp.
Name:  picture from dyno in HP tuner.JPG
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
