#15 |
Resident Land Surveyor
Drives: 2016 Camaro 1SS - Summit White M6 Join Date: Aug 2016
Love everything about it. I'll hopefully be having a house built this time next year, so your garage will be among the samples I show the builders
2016 Summit 1SS 49th Anniversary Commemorative Limited Plutonium Edition - M6, Solo Axleback & !RearCats, Ultra-Rare Cloth Seats, Forgestar CF5V 19x10-285/35 19x11-325/30
2001 NBM Trans Am WS6, Wifey's Grocery Getter - Torquer V2 cam, Racetronix Fuel Pump, Yank 3000 Stall, Transgo 1-2 kit, TSP LTs, Magnaflow, Strano Springs/Koni STR.T shocks, 17x9.5/17x11 TTIIs, Ed Wright tuned |
#16 | |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
#17 | |
![]() ![]() ![]() Drives: 2019 CLA 450 Mercedes Join Date: May 2016
First is the grind down of the current floor for prep. 1) First layer is the epoxy - let dry 4-5 hours 2) Coloring / texture layer - full layer (1/4-3/8" thick) * This is where your color pattern goes in (dozens to choose from) * Setup over-night * Cross swept - first diagonal is to remove excess * Second diagonal is even out floor 3) Sealant - you have a textured / colored floor of your choice * 36-48 hours to fully cure * Floor is close to 1/2 thick with real texture Lifetime warranty
2019 Lunar Blue Metallic Mercedes CLS 450
2021 C43 AMG Mercedes Coupe Metallic Cardinal Red 2014 Lincoln MKT EcoBoost (The Bus) |
#18 | |
We really wanted this to be one and done. Both the flooring and the cabinets have lifetime warranties. Neighbors stop and ask to see the garage.
#19 | |
Sure, why not?
#20 |
My ideal garage would be a 2 car with a tandem 3rd on one side that has enough room for a lift in the future. Kind of a shop within a traditional garage. I spend a LOT of time in either my dad's or my brother's shop, so it would make sense for me to spend a larger chunk of my budget in the garage knowing I'll be in there quite a bit with both of our cars along with any future Camaro or 4th gen f-body projects I curse myself with
![]() Yours will definitely inspire the floor and shelving style in mine if I can help it.
#21 |
![]() Drives: 2018 ZL1 1LE Join Date: Aug 2017
Here's what we did in ours.. Love the coating you installed
#22 |
![]() Drives: 2016 Camaro 2SS Join Date: Nov 2017
I might never go in the house if I had a garage like that..
#23 |
Now that's a garage!! For us, the downsizing was critical. We are both nearing the point where we pull the rip cord and jump out of the work force.
The garage will be an entertainment area, when needed. Back out the cars, setup the tables and chairs and bring on 300 pounds of crawfish, crabs and shrimp. When it is over, turn the pressure washer on and hose it down. Doors open and fans and two hours later, pull the cars back in. I am waiting on my HVAC guy to come and give me my choices for the split unit heat pump. That should go in by mid-September.
#24 |
I just installed one. It works great !! I wont be using the heating part because it has in floor heat but it cools down to a nice 70 degrees. I used a 3ton capacity.
