#15 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Next time you have a chance, hold a K&N up to the light and see the holes in the gauze letting light through. Then decide if you think it will stop particles from entering your engine. I know people use them, but i'm not a fan.
#16 |
Retired from Car mfrs....
I put KN filters on three or four of my cars, then finally got smart, realized that I was just wasting my money, I don't care about an extra 5 hp .
#17 |
Guaranteed it lightened your wallet. That's about all you'll get.
#18 |
![]() ![]() ![]() Drives: 2015 Z/28, 2007 HHR Join Date: Jan 2014
#19 |
![]() Drives: 2017 2SS Join Date: Jun 2014
Let's say that a K&N gives 5hp - that's a "best case scenario". That's a 1.09% increase in power.
According to this formula , a drop of 20*F (from 77* to 57*) nets a 1.02% increase in power.In other words, the difference in air temperature between night and day where you live gives almost the exact same HP increase as a K&N. So, if you can tell a difference between your HP at night and your HP during the day, then you might notice the HP increase from a K&N. |
#20 | |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
#21 |
![]() Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
Like others have said, Not much HP improvement, MAYBE 2-5HP on a dyno, BUT, When was the last time that YOU drove around at FULL THROTTLE? LITTLE or NO gain at part throttle AND You are NOT stopping all that dirt from getting into Your engine.
#22 |
![]() Drives: '20 ZL1 M6 Join Date: Apr 2017
FWIW, I had a K&N and went back to OEM.
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
#23 |
![]() Drives: 2018 2SS Join Date: Jan 2018
No
#24 |
Drives: 17 SS 1LE | 07 S2K Join Date: Sep 2017
I have to look at these things a bit differently, which I think helps.
If you aren't changing ANYTHING but the filter... stock airbox, intake manifold, etc.. and ONLY the filter changes... the only way you'll see an increase in power is if you are flowing more air THROUGH this filter. This means the filter is not filtering as much, effectively giving you 2-5 HP by letting more particulates and silicates into your engine to do damage. Sounds awesome. |
#25 |
![]() Drives: 2016 Red Hot 2SS M6 Join Date: May 2015
Isn't the K&N cheaper over time than using OEM filters though? I thought it was re-usable?
#26 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
I think I bought the stock AC Delco filter for about $20. I changed it after 2 years. The K&N costs $56 dollars, so it'll take about 6 years to break even for me.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
#27 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
And ppl spend $400 for a cai to give 9hp but the kandn is stupid for $50?
I am trying to decide whether to go drop in or cai
#28 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
You can expect more dirt getting into your engine.
