Old 08-10-2018, 12:08 PM   #15
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
I hope to pull similar numbers. I think our mods are identical except I went the catless LT headers route vs the offroad pipes. . Going to wait for the heatwave here to break. Was that really 76 degrees at the dyno? Man! It's 86 here when I wake up.
Dysan911 is offline   Reply With Quote
Old 08-10-2018, 12:46 PM   #16
Eyefixstuff
Eyefixstuff's Avatar
Drives: 16’ 2SS A8 HBM Procharged
Yes it was later at night. During the day has been very hot. Much cooler when the sun goes down.
16' 2SS A8 Hyperblue | P1SC-1, Race IC | JMS fuel pump voltage booster | Jannetty custom tune | Elite E2-X catch can | M017 Wheels
Eyefixstuff is offline   Reply With Quote
Old 08-10-2018, 09:01 PM   #17
DapperDan
DapperDan's Avatar
Drives: 2017 1SS A8 Nightfall Gray
Awesome!!! Gotta get to the track now.
What cat delete pipes did you go with?
DapperDan is offline   Reply With Quote
Old 08-10-2018, 10:57 PM   #18
Eyefixstuff
Couple weeks I’ll get back there. These off road pipes I got from Ted. I think they may actually be part of the Hellion kit. Bolt to manifolds and deletes all 4 cats. Sounds very angry at open throttle.
Old 08-11-2018, 11:59 AM   #19
oldman
Drives: SS 6 speed of course
I finally got around to putting cats into the LT, best mod to date. It really made the engine behave better at low RPM in gear like 50 MPH in 6th gear. Less to no rasp at all too was a bonus..
Please do it now, don't kill your starter, a partial header wrap and a starter wrap is needed. WOT fun on a supercharged car, LT and heat will kill a start very quickly (ask me how I know).
Old 08-13-2018, 06:58 PM   #20
Eyefixstuff
a good couch is a great upgrade for even the best marriages.. just saying. Luv the blue color.
So the car has no cats at all correct? Sound really tame compared to my car.
OK not to throw bombs, I'm just point out that the P1sc can and does put out more than double the factory torque just before 3 grand. So I honestly at least for me on street tires don't know why the PD guys keep saying that the centri lacks torque. Don't know! My car can't hook its power to the ground in the first two gears on street tires period.. I can be as gentle and roll into the power all I like, even a small centri will just eliminate any street DD radial tire at an legal speed.
Just a really great power torque curve from a P1S and a near stock install.
I think the torque down there may have more to do with the fuel upgrades and tune than the blower, but comparing the chart to a whipple chart also posted a couple threads down does confuse me though. You would think the PD blowers would have much more hp and torque down low but if you compare them side by side they’re actually much closer than I would have thought. But then the HP doesn’t taper off near redline either.
Old 09-02-2018, 12:57 PM   #21
Spooky_SS
Drives: 2018 Camaro SS 1LE
How are your IAT's with the race IC?
Spooky_SS is offline   Reply With Quote
Old 09-04-2018, 08:40 PM   #22
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I would love to know as well. The only thing that worries me about that setup is the intake right over the headers..?!? Do your IATs go up when the hood is closed? Just wondering how the fresh air gets to the filter. Thanks!
Edit: Just realized you’re only an hour from me. Would love to check out your blower setup in person sometime.
Old 09-04-2018, 09:02 PM   #23
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
Can’t speak for the OP, but my IAT’s are very reasonable even with the intake where it is. The IC does a very good job keeping thing cool.
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 09-04-2018, 09:21 PM   #24
Eyefixstuff
My IAT’s have been excellent. I posted some numbers in this thread if you would like to see.
https://www.camaro6.com/forums/showt...=536109&page=2
Old 09-04-2018, 09:53 PM   #25
Joshinator99
Moderator
Good read, thanks
Old 09-04-2018, 10:00 PM   #26
Dysan911
Dysan911's Avatar
Once the car starts moving about 5+mph the heat under hood gets sucked right out basically and the IAT's do drop right down to almost near ambient. Also keep in mind the intercooler is outside the engine bay sorta like that Cold Air Kit after all.
Old 09-05-2018, 06:17 AM   #27
Joshinator99
Moderator
Sounds good if the airs getting pulled out once you’re moving. The IATs look good with the upgraded IC, so that’s what matters. I’m looking at the Procharger vs Maggie and just figured I’d ask the question. Guess I could ceramic coat the headers too to help keep ingested heat down (probably a good idea for any setup). Thanks for the feedback.
Old 09-07-2018, 05:55 PM   #28
Drsagacity
Drsagacity's Avatar
@Josh I think regardless of the blower choice you will see the same IAT results. . .once the car starts moving IAT’s drop no problem. The way I have been logging runs over the past several weeks the IAT’s definitely jump up after a spirited run when I pull in and turn the car off...then when I go to make another run, cruising out of the neighborhood, all is right in the world...IAT’s back to their happy place.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
