Old 08-07-2018, 05:42 PM   #15
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
Originally Posted by shaffe View Post
Possibly but isn't the reason we are seeing more 8, 9 and 10 speed transmissions because they are supposed to be more efficient than what they are replacing?
True, but they also allow better use of the powerband, so there is a performance benefit as well. For a performance car, performance will be the priority.
In the average family car, the TCU/ECU will try to get to the highest gear as possible as quickly as possible. For performance, that's the last thing to you want. You want the most appropriate gear to stay in the powerband, and you want to hold that gear as long as required. That will cost some mileage.
Sure, you can hold the gear in manual mode, but the computer will be a lot quicker at choosing the right gear. Just my rambling 2 cents.
torqueaddict is offline   Reply With Quote
Old 08-07-2018, 06:06 PM   #16
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
I believe most of the fuel economy benefits come from the power flow through the clutches and reducing viscous friction loses with the pump and having as few a number of rotating clutch packs engaged as possible in cruising gears. This along with the TC pickup strategy, which I doubt is about the same as the 8L80.
The fuel economy number is probably just a misprint, or the regulations changing.
cmitchell17 is offline   Reply With Quote
Old 08-07-2018, 06:16 PM   #17
motorhead
Old 08-07-2018, 07:13 PM   #18
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Here's a summary of the model year 2016 - 2019 fuel economy data (see pic below). The raw data is available here: https://www.fueleconomy.gov/feg/download.shtml
It does look like the 2019 fuel economy shifted downward 3-4% compared to the 2016-18 data. I'm not aware of test procedure changes specific to 2019 that would impact the numbers, but I plan to look into this further. I did look at the Corvette fuel economy data between 2018 and 2019 and don't see a similar shift.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 08-07-2018, 07:21 PM   #19
torqueaddict
^^I doubt the 6m gear ratios have changed so that 4% difference is a little puzzling assuming the testing procedures are identical.
Old 08-07-2018, 07:28 PM   #20
vtirocz
vtirocz's Avatar
The gear ratios have not changed (at least not that I'm aware of), but the aerodynamic characteristics may be less favorable (ie. increased drag), which would impact the fuel economy numbers. The engine/trans calibration may also have changed, which could also impact the #s. It could also just be run to run variation. It is suspicious that the drop came in 2019 and didn't see much variation from 2016 - 18.
Old 08-07-2018, 07:39 PM   #21
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
I think its Oxygen Starvation making the motor run rich.. ..the Oyxgen see's that front of a challenger knock off heading right for it - freaks out and goes and immediately dodges, going around the car.
Need4Camaro is offline   Reply With Quote
Old 08-07-2018, 08:07 PM   #22
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Looks like we can conclude the new front end isn't as good as the old one
thescreensavers is offline   Reply With Quote
Old 08-07-2018, 10:22 PM   #23
STYLO LT1
STYLO LT1's Avatar
Drives: 2016 Camaro SS Vert.
STYLO LT1 is offline   Reply With Quote
Old 08-08-2018, 12:55 AM   #24
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2019 ZL1 on Order
interestingly the ZL1 Figures are showing better in 19 v 18
Modern07 is offline   Reply With Quote
Old 08-08-2018, 04:45 AM   #25
V8 Firebird
V8 Firebird's Avatar
Drives: ⚡Electric TM3 ⚡
After I read this one, I think 19 Camaro could have more downforce that cause it get bad MPG, or it might have better MPG while driving.
httphttp://gmauthority.com/blog/2018/08/2019-camaro-ss-and-its-three-unique-aerodynamic-features/
I always miss that awesome bird.
V8 Firebird is offline   Reply With Quote
Old 08-08-2018, 05:28 AM   #26
vtirocz
vtirocz's Avatar
Can you elaborate on what you mean by “might have better mpg while driving”?
Old 08-08-2018, 07:04 AM   #27
JT58
Drives: Former 2016 Camaro 1LT
It does matter- and is why I bought a V6 Camaro with automatic transmission and not an SS. And the V6 runs on regular gas too- it makes a difference to some of us like me who uses the car as an every day long distance commuter- and I got over 30 MPG in my RS.
But what is most important is hopefully it will be better than the outgoing A8, which has been problematic for some- and in my case so bad I got rid of the car after waiting 3 weeks for the dealership to attempt to fix it to no avail. It's too bad- I loved the car and had to get something else that I don't like as much but unfortunately will not buy GM again.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
JT58 is offline   Reply With Quote
Old 08-08-2018, 07:13 AM   #28
yankee
yankee's Avatar
Drives: 2018 Camaro LT RS, 2015 Mazda 3
So the refresh is worse inside-out, eh?
yankee is offline   Reply With Quote
