Old 08-06-2018, 11:14 AM   #15
Drsagacity
Drsagacity's Avatar
I need to talk to Ted, but I'm thinking I will probably follow Steelheadrob's lead and do the LT4 stuff now (already have the in-tank pump) and save the cam & pistons for a winter project. Even though I'm planning to retire in a year, I'm busy as hell in the meantime and my car will probably be down for better than a month for the internal stuff. May as well enjoy it now while the weather is nice.
Drsagicity, Looking good! I envy your access to a shop with a lift! Did you do just the pistons, or pistons and rods? Apparently you did just "drop" yours in as I don't think you had time to balance.
We did the drop in pistons only (no rods). My plan is to stay under 800whp (shooting for 850 at the motor)...so we feel good about this setup without the need to add rods and rebalance. If I decide to add more power down the road, then I would revisit the rod discussion...I just don't see that happening. You figure that at 750whp our cars are probably in the top 1% of all cars on the street. Plus, I don't race...primarily cruising, golfing and top down fun with the kids. For me, kind of how people handle motorcycles, it's about making it uniquely my own.
As for access to the shop, yes, that is huge. I got in with a really cool group of guys back in my Corvette modding days (before wife and kids)...and luckily, they agreed to work on my Camaro too. :-) Although there are a few things that you can tell...it's not their primary platform. . .for this job, they actually used two guys and then I got to jump in and help out:
1. pick up food or buy beer
2. clean car parts
3. Perform searches for those one-off non-Vette questions.
4. Hold the flashlight when needed
5. Find things they misplaced (like tape)
Still, I love doing this because I learn so much just hearing and watching them. It really is awesome...
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 08-06-2018, 01:01 PM   #16
L78toLT1
L78toLT1's Avatar
2. clean car parts
It sounds like you're having fun in addition to learning new stuff, which is the whole point I suppose!
When replacing the pistons, did you hone the cylinders or replace the rod bolts/bearings?
Baby Blue
Old 08-06-2018, 01:04 PM   #17
Drsagacity
Drsagacity's Avatar
Yes to all. Hone bolts, and bearings...gapped all of the new rings. The big thing was that the ring gap was crazy tight on the stock pistons...clear why there are problems with stock pistons.
TBD performance
Old 08-07-2018, 04:13 AM   #18
Driski
Drives: 2016 Camaro Convertible 2SS
He will be able to use it for sure. I did the initial install of the Supercharger and he planned it with the new mods to be able to drive it anywhere, then throw the drag pack on it and take it to the track. It should make over 700 at the wheels with ease.
Thank you and Drsagacity for the feedback
2SS Convertible, MRC, NPP, A8, Garnet Red, Blk Bowties
GM CAI, Ported TB, Kooks Headers, E85
Driski is offline   Reply With Quote
Old 08-07-2018, 01:28 PM   #19
chrest
chrest's Avatar
Drives: 2017 Camaro 2SS
cant wait to hear this fire
2017 NGM 2SS NPP M6 MRC
Vortech SC, 2" TSP LT No Cats, Borla X, Eibach,
Hurst shifter
603hp/547tq
chrest is offline   Reply With Quote
Old 08-08-2018, 02:58 AM   #20
Drsagacity
Drsagacity's Avatar
Well, the wicked ss is alive. Sorry, no revving, this was after the first start with the cam, headers, race pipes and pistons installed.
https://youtu.be/JX6b-ZPyPVE
TBD performance
Old 08-08-2018, 06:44 AM   #21
laynlo15
Drives: 2022 Lt1 A10
Your guys did a great job, 4 days from start to finish is pretty stellar also and probably could have finish a little earlier if you'd had the correct tank pump. Glad I could help with the initial SC install and loading your first tune from you HP tuners. Great build and that thing is gonna be a wicked piece. See you on the dyno in a few weeks.
Old 08-08-2018, 07:24 AM   #22
L78toLT1
L78toLT1's Avatar
The Wicked SS certainly has a sound befitting its name! I'm sure it will have the performance to back it up as well!
I'm about to follow almost exactly in your footsteps for my next phase. I will probably go with the smooth idle cam though. I like the stealth approach.
I'm anxious to see your dyno results and to get your overall impressions on this setup after living with it for a while. Have fun and keep us posted!
Baby Blue
Old 08-08-2018, 08:47 AM   #23
Drsagacity
Drsagacity's Avatar
We do still have to button things up. Run wires for boost a pump and the gauges. I will pick the car up tomorrow and start data logging. But yeah, these guys were really good.
TBD performance
Old 08-08-2018, 08:51 AM   #24
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Sounds good! Sounds pretty mild for it being a rough idle cam...I wouldn't want any more then that, it's perfect!
Old 08-08-2018, 08:54 AM   #25
Drsagacity
Drsagacity's Avatar
I really struggled with the rough idle vs smooth idle decision. In fact, I placed the original order with the smooth idle cam. Ted confirmed performance will be the same either way. I just decided at the end, I would enjoy the rough idle more, especially with the kids. Biggest question will be figuring out if this setup as drone, if so, I will change the axleback.
As far as performance, that's the beautiful part of going this route. Ted has a tried and true setup which kind of takes the guesswork out of it. I would expect 675whp on 93, 700whp on e85 and 770whp on race fuel. That's assuming I stay at 9psi and more likely, I will bump to 11 psi (so you can bump each config up by about 50whp).
May wait to bump boost when I get real tires.
TBD performance
Old 08-08-2018, 10:07 PM   #26
Drsagacity
Drsagacity's Avatar
Bam. I get to pick the car up tomorrow night. @tedjannetty, will start logging and get you the first info on Friday.
TBD performance
Old 08-09-2018, 08:44 AM   #27
ShizzySupra
Drives: 16' Camaro 2SS
I wish I could make ~820whp at 11 psi :( Good luck man should be a blast!
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R
9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp)
ShizzySupra is offline   Reply With Quote
Old 08-09-2018, 09:39 AM   #28
Charlie540i
Drives: 2016 Camaro SS
My personal experience with the Maggy is 815-820whp with 13-14psi.
Charlie540i is offline   Reply With Quote
