Old 08-05-2018, 06:33 AM   #15
laynlo15
Drives: 2022 Lt1 A10
That head doesn't appear to be salvageable to me. I'd order a new head.
Old 08-05-2018, 07:08 AM   #16
zr1chris
zr1chris's Avatar
Drives: 2018 Camaro 1SS/1LE
Watching the video very closely it's hard to tell but I think I see a hint of smoke out of the exhaust just before missing the gear, then of course once you missed 4th on came the smoke show. I'm thinking it was on it's way out already and missing 4th just finished the job.
zr1chris is offline   Reply With Quote
Old 08-05-2018, 08:17 AM   #17
Camaro_QC
Camaro_QC's Avatar
Drives: 08 Tiburon GS, 2018 Camaro 2.0T
Originally Posted by Vtor_ZL1 View Post
Another winner.. courtesy of street racing.
Exactly what I was thinking. He got what he deserved...
Street racing is bad.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
Order WDGHKX
1100 - 5/08/2018 | 3800 - 6/18/2018
2000 - 5/09/2018 | 4200 - 6/21/2018
3000 - 5/28/2018 | 5000 - 6/27/2018
6000 - 6/29/2018
Camaro_QC is offline   Reply With Quote
Old 08-05-2018, 08:48 AM   #18
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
The 2-3 shift is clearly a no-lift-shift. So is the next one. Very high pitch under throttle for a split second ... that's a no lift shift from 3rd to 2nd causing mechanical over-rev.
Street racing notwithstanding, IMO the OP can't blame anyone but himself.
Old 08-05-2018, 07:20 PM   #19
DatBrotato
DatBrotato's Avatar
Drives: '18 SS 1LE M6
Clearly you haven't seen a 3-2 shift. It never went into 2nd and I most definitely didn't let out the clutch
It didn't see a gear after 3rd.
The shop owner, mechanics, tuner, and vengeance has seen the video. They all agreed it was a free revv.
'18 1SS 1LE M6 NGM|| 11.5:1 Diamond Pistons || Callie's H-beams || Vengeance III Cam Kit || Built Heads || TSP LTs 1 7/8"(C-Coated) || MSD IM || DSX E85 || Rotofab || BMR Springs || 576/472 @7000rpm
DatBrotato is offline   Reply With Quote
Old 08-05-2018, 07:41 PM   #20
DatBrotato
DatBrotato's Avatar
Good eye, I didn't catch the smoke in 3rd
Old 08-06-2018, 06:55 AM   #21
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
Curious, but what shop did the work?
Old 08-06-2018, 07:06 AM   #22
ZNix
Drives: 1987 Buick Grand National
Nobody deserves a broken motor.
You're a turd, get out of here with that.
GL OP. Hope you can get everything fixed. Ill have to give the vid a watch after work.
ZNix is offline   Reply With Quote
Old 08-06-2018, 07:53 AM   #23
DFW1LE
DFW1LE's Avatar
yep all indication would be a phaser problem, either it fell apart, or they forgot the limiter / lockout, Vengence sells a lockout setup.
As Oldman and others mentioned, the cam phase limiter or lack thereof might have caused the problem assuming the tune was good, however, I would also note that some of these stage 3 cams offered by various companies may require fly-cutting the pistons for clearance, thus the need to check PTV.
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ
Old 08-06-2018, 08:54 AM   #24
DatBrotato
DatBrotato's Avatar
Speedtek in Fort Worth.
I'll follow up with the shop and see what they did with the phase limiter.
I spoke with vengeance twice and they didn't mention a flycut. They did however warn to not run thinner gaskets or mill the head with this cam, which means it was right on the bleeding edge of needing a flycut
Old 08-06-2018, 09:06 AM   #25
62nalide
62nalide's Avatar
Drives: 2013 SS
Damn, who spec'd the cam? .660'' on the exhaust?
62nalide is offline   Reply With Quote
Old 08-06-2018, 01:39 PM   #26
TJay74
These engines don't have a rev limiter like the older stuff. The throttle just closes so you don't bounce off anything...much easier on the engine that way. It was bouncing because something was mechanically wrong (obviously).
Based on what I have seen in the OEM tune there is a rev limited in the programming. It isnt all just throttle based.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 08-06-2018, 02:08 PM   #27
DatBrotato
DatBrotato's Avatar
It made really good numbers on the Dyno, so no complaints there.
Exhaust valve was the one that got tagged/broke off. Wonder if there's a correlation
Old 08-06-2018, 03:30 PM   #28
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Yea its spark and throttle based... My point was on these engines the limiter does not act the same. I can be wot on the limiter and the rpm doesn't bounce like a older LS engine does.
