#15 | |
![]() Drives: 2018 ZL1 A10 Join Date: May 2017
#16 |
![]() Drives: 2017 garnet red zl1 2022 AT4 HD Join Date: Nov 2016
Yes it is an issue. I recently had a thread on it, along with another member. Both similar symptoms and solves. It makes a huge difference in power
#17 |
![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 Join Date: Aug 2009
BTR has one called BIG 3 RACING 6th GEN ZLI Heat Exchanger Tank.
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir Glassskinz rear window valance . 2012 ZL1 A6 (SOLD) Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC. Alky Control, FIICHILLER. |
#18 |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
Cordes has a nice one that I just installed: https://www.facebook.com/commerce/pr...010469798&rt=6
It is a 1 gallon tank and they include everything you need for install. I will setup a thread for it shortly this weekend
#19 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Looks nice. I'd like to see it installed. I'm going to stay completely stock for at least one more winter, to see if I can improve my time before I start adding a few little things that won't void my warranty.
Full exhaust, lower pulley, E35 -10.36 at 133 mph 690 DA straight from the street with a slight spin at launch. TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
#20 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
#21 |
i'm also curious as to how this solves the air in the system issue the OEM set up has
#22 |
It makes it easy to screw off a cap and fill to the top. Then easily re-check for any air after fluid has circulated. The current check is really hard to tell.
Plus it adds volume to your system. I had a D3 Reservoir on the 5th Gen.. |
#23 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
It has worked flawlessly! I have the initial kit with the smaller reservoir. It looks factory and I've never encountered an issue with it.
#24 | |
![]() ![]() ![]() ![]() ![]() Drives: Grandad's C2 L89 Join Date: May 2017
2018 ZL1 1LE sw/PDR
#25 |
![]() ![]() ![]() Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
If a catch can can void our warranty... won't this as well?
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
#26 |
Technically Yes, but rare to have that actually happen.
#27 |
Thank you Al Oppenheiser!
#28 |
The only way it "should" void the warranty would be due to a freeze/thaw failure from someone not using the proper coolant in the winter, corrosion for the same reason, leaks in and around the tank and hoses you installed, and possibly any damage that might occur if the system was believed to have been ran dry. So that could be anything related to the supercharger and the intercooler system. So while it is possible the dealer may void the warranty, it is highly unlikely anything would go wrong with the system to cause you any issues. I would definitely speak to your service manager before doing any kind of mod, if keeping your warranty is important to you.
