#15 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
I have the elite X2. works awesome.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
#16 |
REAPER1LE
Reports from a few of my engine builders state. The new pvc systems in our lt1 we do not require a catch can . They also point out if you do short trips and engine never gets to operating temps yes get a catch can otherwise DO NOT NEED.
#17 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS/1LE Join Date: Sep 2016
The generous coating of oil on the inside of my intake manifold at 1800 miles says otherwise...
#18 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 1SS 1LE Join Date: Sep 2017
It's a hose that goes from the valley cover to the intake manifold. The fresh air side was revised in the LT1 utilizing both valve covers and a "separation" chamber between the valve covers and the intake bellows. Any time the engine is operating under vacuum, in other words any time not at WOT, the dirty side of the system is functioning. This is why a catch can is needed. I've had mine on for about 4000 miles and collected about two ounces of oil. Might not seem like much, but it's oil that would have formed carbon on the pistons, cylinder head, or the valves. YMMV
'18 1SS 1LE Black, PDR
#19 | |
![]() ![]() Drives: 2018 Redline Edition 2SS Join Date: Dec 2014
2018 Redline Edition 2SS- A8, NPP, MRC, Recaro seats, ECS Novi 1500 tuned by EFX, cat deletes, Mighty Mouse Wild CC, GM STB, smoked ZL1 3rd brake light, Xpel XR Black 35% tint all around, Street Scene front splitter, C7 Carbon ZL1 side skirts Drake Muscle Car wicker bill, Adams Polishes Ceramic Coating
2010 Infiniti G37x Sedan for the DD. |
#20 |
![]() Drives: 2017 50th Camaro SS Join Date: Jul 2016
Who are these engine builders??
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
#21 | |
![]() Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
What he said. As much crap as I dump out of my Elite CC, I wouldn't run without it. |
#22 |
![]() Drives: 2018 SS 1LE Join Date: May 2018
Doesn’t get any better than the MightyMouse Catch Can
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl Last edited by JonD; 08-12-2018 at 07:59 PM. |
#23 |
Done! Man these are nice
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl |
#24 |
![]() Drives: 2017 2ss, m6 Join Date: Jan 2017
The large breather on top would lead me to believe that at some level that can is defeating the PCV function?
#25 |
The filter has a rubber diaphram & the clean side has a check valve as well
#26 |
![]() Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2018
I went UPR. Used them before on other cars as well as my buddy.
#27 |
![]() Drives: 2018 Camaro SS Join Date: Feb 2018
Do all catch cans need a check valve on the clean side? I've seen different opinions throughout this forum.
I noticed that the Mishimoto does not have one, and my kit from Elite came with the option but I did not believe it to be necessary. Any opinions? |
#28 |
only if your are running forced induction.
