Old 07-29-2018, 01:23 PM   #15
hawk02
Coupe Newbie
hawk02's Avatar
Originally Posted by ninetres View Post
They don’t make the FF04 in 19s. At least they didn’t 8-10 months ago when I asked them to.
If you can't get the FF04s in 19s, I think the 20s still look darn good on the ZL1. If I remember correctly, you lose about 7 lbs a corner over the stock wheels.
Old 07-29-2018, 01:40 PM   #16
Alain
Alain's Avatar
Originally Posted by 2010REDSS View Post
The OEM Z/28 wheels work perfect on the ZL1 1LE....and....I get comments all the time that they look better too.
First pick was last year with Hoosiers mounted, second is this year with Pirellis.
Did you get those Z28 wheels from GM?
2018 ZL1 1LE/Red hot
Old 07-29-2018, 01:52 PM   #17
2010REDSS
2010REDSS's Avatar
Drives: 2018 ZL1 1LE
OEM takeoffs from fellow forum members.
2018 ZL1 1LE "RAZECAR"
2016 2SS Convertible "NOTOPSS" (Sold)
2015 Z/28 #306 "ITZFAST"
2010 2SS Coupe "FASSTER" (Sold)
2002 SS/RS "02FASST" (Sold)
2007 Factory Five Racing GTM "REDBLUR" (Sold)
"There are two kinds of cars. Red....and everything else!"
2010REDSS is offline   Reply With Quote
Old 07-29-2018, 02:04 PM   #18
69 Z11
69 Z11
69 Z11's Avatar
Drives: 2017 ZL1 vert, 1969 Pace Car
Wow, that looks awesome! Absolutely perfect looking and no fitment issues at all? Standard Z28 tire size?
69 Z11 is offline   Reply With Quote
Old 07-29-2018, 02:46 PM   #19
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Understand that you will be slightly limited on what camber you can achieve if you use a 1LE/Z28 wheel on a regular ZL1/SS with mag ride dampers. For those that want these wheels for the street, you will have no issues. However, those that want the wheels for track usage won't be able to get enough camber unless you cut off a piece of the strut or run a wheel spacer up front.
seanblurr is offline   Reply With Quote
Old 07-29-2018, 03:18 PM   #20
RSFR
RSFR's Avatar
Drives: ZL1
I'm running -2.8 degrees camber up front using a 3mm spacer from ZL1 addons. Works great.
RSFR is offline   Reply With Quote
Old 07-29-2018, 03:20 PM   #21
Yeah, when I first looked at these I didn't have a 1LE so they were okay, not perfect, but definitely in play. I see they do have the FF15 in 19 but not wide enough. Too bad they sort of made these wheels as in-betweeners so they fit the SS as well.
Tire sizes really prohibit that and no 12" widths.
The Z/28 wheel is a tad narrower than the ZLE wheel and most running regular ZL1 or SS aren't adjusting camber. I'd say the Z/28 wheel would be pretty good for them.
Right now I'm leaning toward another set of OEM ZL1 1LE wheels unless I find some Z/28 take offs at a good price.
Definitely the best why to go that I have seen
Old 07-29-2018, 04:06 PM   #22
Mcmillion
Drives: 2018 ZL1 1998 SS 1992 Typhoon
Originally Posted by 69 Z11 View Post
I would love to see a ZL1 with OEM Z28 19" wheels, has anyone done this?
Fit great
Mcmillion is offline   Reply With Quote
Old 07-29-2018, 04:13 PM   #23
TMS
TMS's Avatar
Drives: 2018 ZL1 1LE - HBM, PDR
Originally Posted by RSFR View Post
I did 1LE spec'd wheels, but I figured if I'm gonna get wheels, they might as well be a little different than everyone else.
Love these wheels. Are they BC Forged RZ10s?
Sent from my SM-G950U using Tapatalk
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
TMS is offline   Reply With Quote
Old 07-29-2018, 04:14 PM   #24
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Yup, 3mm is enough.
The front Z28 wheel is identical, the rear is .5" narrower.
Old 07-29-2018, 04:22 PM   #25
Yup, 3mm is enough.
That's what I meant by tad... 11.5 vs 12 on the rear and with no camber plates on the SS or regular ZL1 this wheel works great.
Personally I like the looks of the 1LE wheel better but would easily go Z/28 for a deal.
Old 07-29-2018, 04:43 PM   #26
RSFR
RSFR's Avatar
Drives: ZL1
They are.
Old 07-29-2018, 04:56 PM   #27
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
They look great on SS 1LE's too! No spacer up front, just the profile grinding on the struts. No rubbing with 315 / 345 Hoosier R7 combo either, though, other than one day with those, I've been running 305 / 325 G3R's.
RUQWIKR is offline   Reply With Quote
Old 07-29-2018, 06:43 PM   #28
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
Originally Posted by Mcmillion View Post
Fit great
That looks awesome. I personally think that is the best camaro wheel design.
Now I need to get some for myself.
Thanks for posting these pictures.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
