Old 07-23-2018, 09:04 AM   #15
RXtacy
RXtacy's Avatar
Drives: 93 RX-7, 17 SS 1LE, 04 RX-8
Originally Posted by JeromeS13 View Post
I was able to get -2.5 degrees in the front, and had about 6mm of clearance between the wheel and the strut.
Originally Posted by Alpha1BC View Post
Right, sorry I meant needing to grind out the bolt-hole on the strut. I could only get -2 because that's all the holes on the struts would allow. No issues with tires or rims clearing anything.
There is some variance to the tolerance stack up. I was able to get -2.5 also, but my buddy maxed out at ~ -2.3 IIRC. Usually one side has slightly less than the other so that is your limiting factor.
That being said a little grinding to the bolt slots and you can get even more.
RXtacy is offline   Reply With Quote
Old 07-23-2018, 09:45 AM   #16
TrackClub
TrackClub's Avatar
2.6F with no issues right at a (competent) GM delaer with zero grinding. 1.6 rear.
Old 07-23-2018, 10:37 AM   #17
Dave-ROR
Drives: A few
If you're lucky you might be able to get -2.5 out of the front without modification. I am maxed out at -2. To get more, I'd either need to grind out my struts or get camber plates.
I got -2.6 on mine
I assume it's maxed out.. ironically it was set to -2.6 F and -1.9 R as picked up from the dealer - new. However, that dealer clearly set it that way as the OEM paint torque check marks no longer lined up.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback
Too many cars.. never.
Dave-ROR is offline   Reply With Quote
Old 07-23-2018, 11:04 AM   #18
JeromeS13
Drives: 2017 1SS/1LE
Odd. It's weird how some of us can get -2.5 or so and some can only get -2.0 or so without modification.
Old 07-23-2018, 11:18 AM   #19
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Originally Posted by Dave-ROR View Post
I got -2.6 on mine
Wonder why a dealer would even touch an alignment on a new car.
'18 1SS 1LE Black, PDR
Old 07-23-2018, 11:27 AM   #20
TrackClub
TrackClub's Avatar
Maybe it arrived visibly "disturbed"? Or maybe the dealer took it out on track lol!
Old 07-23-2018, 11:50 AM   #21
Boost Creep
Drives: '18 1SS 1LE
Old 07-23-2018, 01:09 PM   #22
Dave-ROR
Drives: A few
lol didn't have enough mileage on it yet for that.
Absolutely no idea why they changed it though.
-Dave
Old 07-23-2018, 02:10 PM   #23
Bluebarchetta
Drives: 2017 SS 1LE
When I test drove mine, I swore the alignment was off. I'm generally very sensitive to this. Tech drove it and thought the same, however after checking, alignment was fine (I even watched them check it). It was the horrible roads around the dealership, exaggerated the tram lining of the large tires, making it feel out of alignment.
Perhaps someone from your dealership felt the same thing, and thought the alignment was off/needed fixing. Now why did they set it to a track spec....maybe the technician tracks his cars, lol
Bluebarchetta is offline   Reply With Quote
Old 07-24-2018, 09:10 AM   #24
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
Yeah, maybe I'm just the unlucky one that got parts on the edge of the spec limits in this case. We had the bolts that go through the strut pushed out of the knurls and the adjustment screw that goes into the top of the knuckle was pulled out. I got -2.0 on one side and -2.1 or -2.2 on the other so we set them both to -2.0 and called it a day. I guess I'd rather have that be the issue with the car than something more serious lol.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
