Old 07-17-2018, 08:06 AM   #15
Buzzberd6
Buzzberd6's Avatar
Drives: 2LT/1LE, HPCRX, F250(tow vehicle)
redcoats1976 & Giri. Just curious but if your cars came with the standard 18" wheels you also should have all season tires, which should last significantly longer than the optional 20" 'summer only' runflats.
FWIW, I replaced the original tires that came on my 2LT 1LE before 11,000 miles with two track days and I believe, three Solos on them. There was still some tread left to them (not down to the wear bars) but driving the car in the rain was definitely not a pleasant experience. Which you both are probably familiar with seeing as you live here also. The new Firestone Indy 500's I replaced them with are a vastly different story.
2017 2LS 1LE
'I feel that life is measured in achievement, not in years alone'
Bruce McLaren
Buzzberd6 is offline   Reply With Quote
Old 07-17-2018, 08:40 AM   #16
ICTsccaCamaro
Drives: 2018 ZL1 1LE
My 14 factory tires made it to 3k and now my 18 tires are almost corded at 600miles, be happy you make it to 10k.
ICTsccaCamaro is offline   Reply With Quote
Old 07-17-2018, 08:56 AM   #17
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
I have a 2SS and am over 29K miles on the original tires. I drive moderately-to-spirited, which means I rarely burnout, but almost always take off quickly enough from a stop to nearly break traction.
Had my tread depth measured at Discount Tire last weekend and my fronts are at 4/32", left rear (replaced due to flat tire a few months after purchasing vehicle) at 3/32", and right rear at 2/32".
Time for new tires! I'm going to replace all four at the same time. This time I'm going with non - run-flats so I bought the tire compressor and fix-a-flat juice from my dealership parts department to throw in the trunk, just in case.
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
Old 07-17-2018, 09:11 AM   #18
Godfatha
Drives: 2016 2SS Mosaic Black Convertible
Originally Posted by gpskinzhut View Post
Mine were getting slippery by 9.5k or so. Not a single burnout but a few trips on the tail of the dragon and the winding East TN roads did a number on them in short order. Replaced at a little over 10.
Hello fellow Knoxvillian, or Knoxvillain.
I got about 12k out of my first set, 15k out of my second set, then switched to PS4s and they've lasted much longer.
Godfatha is offline   Reply With Quote
Old 07-17-2018, 10:36 AM   #19
Corvette_Mike
Corvette_Mike's Avatar
Drives: 2018 Camaro SS
I hope to make it to 10k miles. I bought a spare tire and am going to buy non run flats
Corvette_Mike is offline   Reply With Quote
Old 07-17-2018, 11:00 AM   #20
Alanarchy
Alanarchy's Avatar
Drives: 2017 Camaro SS NGM, 2025 F150 XLT
Strange. I had 27k with mixed driving before I replaced them.
Alanarchy is offline   Reply With Quote
Old 07-17-2018, 11:24 AM   #21
ctrlz
Originally Posted by LuvMI View Post
Get a second opinion on the tread wear.
Measure the tread depth yourself. This would not be the first tire shop trying to sell someone a new set of tires.
Also, what part of California?
Old 07-17-2018, 11:24 AM   #22
Jeb114
Jeb114's Avatar
Drives: 2021 300
Learn about tires do a little research.
Notice that the treadwear grade is a ratio and not a mileage. This is because multiple factors determine treadwear rates and most of them are a function of driving conditions and operating environment, and not the tire itself. As a result, actual tire wear will vary considerably within the same tire line.
Jeb114 is offline   Reply With Quote
Old 07-17-2018, 11:31 AM   #23
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
The roads where I live in NC are very abrasive, I usually get about 70-80% out of tires that have a mileage rating. We get enough cold weather, so I'll be getting all-seasons once the OEM Goodyear tires are kaput on my '17 SS.
nancygrl is offline   Reply With Quote
Old 07-17-2018, 11:45 AM   #24
Sp00ner
Sp00ner's Avatar
My first set made it about 18 months, and were killed by the 6 months of track events after year one. I'd guess a good 15k miles or so, not sure exactly, but that included at least 6 track events.
Sp00ner is offline   Reply With Quote
Old 07-17-2018, 06:11 PM   #25
CamaroSS50
Drives: 2017 Camaro Convertible SS Fifty
Oh boy, really?
I have been having an issue with one tire which does not seem to hold air (right front). Mine is going into the shop this week for a full replacement of the convertible top, back interior panels, look over of the transmission, etc.
Question: does the tire & wheel warranty cover tires wearing down so quickly?
2017 Camaro SS FIFTY Convertible
CamaroSS50 is offline   Reply With Quote
Old 07-17-2018, 06:27 PM   #26
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Originally Posted by CamaroSS50 View Post
Oh boy, really?
No. Tire wear is never covered under warranty. Summer tires wear very quick if you drive aggressively.
If you have one tire going down in pressure, it probably has a nail in it.
Old 07-17-2018, 06:54 PM   #27
dfwcowboy
dfwcowboy's Avatar
Drives: 2024 ZL1 M6, 1978 Beechcraft Baron
Tires are generally never covered by the vehicle manufacturer warranty, but sometimes they are covered by the tire manufacturer. All new cars should come with a little booklet from the tire manufacturer and any warranty info will be detailed there. Sometimes tread life is covered, sometimes not. Depends on the manufacturer and model.
dfwcowboy is offline   Reply With Quote
Old 07-17-2018, 07:48 PM   #28
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
I'm at 7200 miles and I'm past my tread wear bars, then ran over a piece of metal, so my car has been sitting in the garage with flat ��. I believe driving on rough roads and it being really hot out may have degraded my tires so fast. I've only done 2 burnots and my fronts tires are only 1mm off of my tears for tread wear.
