#15 |
![]() ![]() ![]() ![]() ![]() Drives: '17 ZL1 Join Date: Jul 2016
Good track cars aren't necessarily good street cars. By modifying an SS 1LE, you are going to shift the balance that GM has established. If you make it better for the street, it'll probably be worse on the track. If you optimize for track, it's going to be worse on the street. If you find a way to make it better all around, the folks at GM will want hear your ideas.
The SS 1LE is perhaps a better track car than the ZL1. If you look at track fast lists it's not uncommon to see SS 1LEs running faster than the ZL1s. For many tracks, it really takes a great/pro driver to manage the power of the ZL1 properly. Heat will probably be the least of your track worries. When you add significant horsepower, you need all of the suspension, aero, tires, etc. to bring the car back to a balanced track car. (Otherwise, the car will be a handful.) In other words, adding a supercharger will almost certainly require some compromise in track capability. You'll just have to decide if that's what you want. Good luck. |
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
I will say this, the centri units will do a lot better on the track than the PD style ones in regards to heat, a lot better.
#17 |
![]() Drives: 2018 Camaro ZL1 1LE Join Date: Jun 2018
bumping this up to see if anyone has any insight yet? Is anyone running the lt4 blower and done track days or any PD supercharger for that matter?
#18 |
![]() ![]() Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
I pass my buddy in his 16 zo6 all the time if that helps..
2017 1LE Hyper Blue
#19 |
#20 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
Honestly.. the ZL1 costs that much more than an SS 1LE because that's how much it costs to create a balanced track car with the additional 200 HP and to keep it cool. Supercharge your 1LE, and you'll probably need to upgrade the axles, cooling, add an intercooler, change spring rates, get custom damping and eLSD settings, etc..
#21 |
The zo6 has a blower and had to add additional coolers over stock to keep from pulling timing from heat. I think the 1le is better in the turns with novice to intermediate driver's.
2017 1LE Hyper Blue
#22 | |
2017 1LE Hyper Blue
#23 |
![]() Drives: 2017 1SS 1LE Join Date: Aug 2017
Ran my Whipple charged 17 1LE yesterday. Slightly damp and my first time at the track, so no new fast lap times, but the takeaway was that I need an additional oil cooler.
IAT2 - 87 degrees Coolant - 230 Oil - 290 after 10 minutes Brakes - DS2500 and SRF - no issues Once the oil got hot it pulled a lot of power, like 10-15 mph down the straight. I think with an additional oil cooler it’ll be fine. It’s ridiculously powerful, and I’m on the canned Whipple tune.
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers |
#24 |
If you're gonna do it why don't you use a procharger? Less heat to deal with..
2017 1LE Hyper Blue
#25 |
I have the mishimoto oil cooler, I ran a track day at camaro fest last year 95 degrees and 90% humidity and my max oil temp for the day was 239. If you do decide to put it on while the front clip is off there is a cover that blocks air flow into the air box, I removed mine, pic below with cover location.
2017 Camaro SS 1LE
Pray ported TB/IM TSP 1 7/8 Long tube headers w catted con pipes Taylor plug wires Mishimoto oil cooler Elite X2 catch can |
#26 | |
![]() Drives: 2018 zl1 1LE Join Date: Mar 2017
Chris, Mike with the other white 1LE from monday. Good to meet you and glad the rest of the day went well after the carnage of the early sessions.
Hopefully see you out there again once you get that thing dialed in. Quote:
2018 ZL1 1LE
2021 GLS63 AMG 2005 SRT4 2017 Ram 1500 Last edited by Ichabod; 08-01-2018 at 08:11 AM. |
#27 | |
Great to meet you - and I'll be back. Did you see the drama on FB about the GT3 that wrecked going into 1?
#28 | |
EDIT: found some discussion on rennlist
2018 ZL1 1LE
2021 GLS63 AMG 2005 SRT4 2017 Ram 1500 Last edited by Ichabod; 08-02-2018 at 06:55 AM. |
