Old 07-12-2018, 03:33 PM   #15
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
Their forged rims, I think that says it all. Whatever you hit that bent a forged rim would have done far more damage to a cheap aftermarket rim. You should be glad they were the OEM forged rims, most likely would have been a much different outcome if not.
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp
VAZL1 is offline   Reply With Quote
Old 07-12-2018, 04:37 PM   #16
Laststandard
Drives: 2018 1SS 1LE
I've managed to put a small dent in both the front and rear wheels on my motorcycle thanks to the wonderful roads here in MN, and it's lighter with more tire sidewall than the Camaro..
2018 1SS 1LE (sold)
Laststandard is offline   Reply With Quote
Old 07-12-2018, 04:49 PM   #17
Retro69
Retro69's Avatar
Drives: 2018 Camaro ZL1
Originally Posted by Emoto View Post
If you don't mind the ride and grip trade-off, setting your tires to a slightly higher pressure can help prevent a rim from impact bends, as the tire provides a little more resistance at higher pressures.
That’s a thought!
Retro69 is offline   Reply With Quote
Old 07-12-2018, 06:28 PM   #18
DangerZL1
Drives: 2023 Black ZL1 Auto
I read posts on the Corvette forum from members with up to 3 bent wheels on a Z06. Some of it would be due to lower quality castings, even if they’re forged. Run flats with stiff sidewalls transmitting the impact of bumps to the wheels compounds the problem.
Old 07-12-2018, 09:49 PM   #19
SpeedLimit
Drives: 2019 F150
I don't think the OEM rims could be considered fragile. The OEM ZL1 wheels I took off mine were definitely in the robust category. The 5th gen ALCOA wheels were lighter and considered far more crash resistant than other wheels. When OEM GM wheels bend on impact, others break.
SpeedLimit is offline   Reply With Quote
Old 07-12-2018, 10:06 PM   #20
satanschariot666
Drives: camaro
y the hell do ppl buy aftermarket rims when the oem wheels are so beautiful
satanschariot666 is offline   Reply With Quote
Old 07-13-2018, 07:38 AM   #21
zman1969
zman1969's Avatar
Drives: 1969 R/S Z28 302 m20 Endura
back when I had my 99 Firehawk, I was leaving Memphis and hit a BAD chuckhole on interstate and later noticed a shimmy in steering at 53-55mph. when I had it up on the rack I found both right wheels bent on inner hoop - not bad but enough. I remember I was surprised that no tire had blown at the time and this pothole was on the interstate!
1969 RS Z/28 302
1969 Firebird LS6-6 speed TA clone
2015 Zl1
zman1969 is offline   Reply With Quote
Old 07-14-2018, 01:58 PM   #22
Retro69
Retro69's Avatar
Well I have an appointment on Monday to get the wheel straightened. We’ll see how they do. They quoted me $125 - $175 depending on what’s needed. Hopefully they’ll do a good job and I won’t have to replace the wheel. The dealer quoted me like $895 for a new one yikes! Looks like I could get one online for about $550ish. Either way it’s a serious chunk of change for a pot hole encounter.
Old 07-14-2018, 02:44 PM   #23
Stoner
Drives: 2017 ZL1 HBM, M6
The Porsche Cayenne Turbo S had 2 major flat spots due to pot hole impacts and had to be replaced. On the Mini Cooper S, (pot hole impact) the inside of the rim cracked and caused an air leak, rim had to be replaced. We have the highest taxes in the nation, and the worst roads.
Stoner is offline   Reply With Quote
Old 10-02-2019, 02:29 AM   #24
YoungFamous
Amos6.2Jr
Drives: 21 A10 2SS 1LE
Are oem ZL1 wheels forged, flow formed or what?
YoungFamous is offline   Reply With Quote
Old 10-02-2019, 06:05 AM   #25
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Forged.
Old 10-02-2019, 03:10 PM   #26
Artos
Artos's Avatar
Drives: A10 LT4
Originally Posted by Larrio Andretti View Post
Not true!
if it was true there would be dozens of threads about warped rear wheels...
Artos is offline   Reply With Quote
Old 10-02-2019, 03:27 PM   #27
C Man
Drives: 2018 White Convertible Camaro ZL1
I had 2 on one side of my car slightly bent. Not bad enough... so when they put on the new tires they added some wheel waits to help balance them a little.
With such rough roads, I am considering 19 inch rims with a little more cushion for the street and keeping the 20s just for the track.
White 2018 Camaro A10 Convertible ZL1
C Man is offline   Reply With Quote
Old 10-03-2019, 12:29 AM   #28
ohsmily
Drives: '19 ZL1 1LE A10 ShadowGrayMetallic
I absolutely walloped my left rear wheel on my 2019 ZLE on a rut on the shoulder of a road going about 15mph. I hit so hard I thought for sure I damaged my suspension. But nope. No wheel damage. No shaking or shimmying at speed. No problems at the track the next eeek.
ohsmily is offline   Reply With Quote
